WebMercatorProjection
The map projection used by Google Maps, Bing Maps, and most of ArcGIS Online, EPSG:3857. This projection use longitude and latitude expressed with the WGS84 and transforms them to Mercator using the spherical (rather than ellipsoidal) equations.
new Cesium.WebMercatorProjection(ellipsoid)
Name Type Default Description
ellipsoid Ellipsoid Ellipsoid.WGS84 optional The ellipsoid.
static Cesium.WebMercatorProjection.MaximumLatitude : number
The maximum latitude (both North and South) supported by a Web Mercator (EPSG:3857) projection. Technically, the Mercator projection is defined for any latitude up to (but not including) 90 degrees, but it makes sense to cut it off sooner because it grows exponentially with increasing latitude. The logic behind this particular cutoff value, which is the one used by Google Maps, Bing Maps, and Esri, is that it makes the projection square. That is, the rectangle is equal in the X and Y directions. The constant value is computed by calling: WebMercatorProjection.mercatorAngleToGeodeticLatitude(Math.PI)
Gets the Ellipsoid.
static Cesium.WebMercatorProjection.geodeticLatitudeToMercatorAngle(latitude) → number
Converts a geodetic latitude in radians, in the range -PI/2 to PI/2, to a Mercator angle in the range -PI to PI.
latitude number The geodetic latitude in radians.
The Mercator angle.
static Cesium.WebMercatorProjection.mercatorAngleToGeodeticLatitude(mercatorAngle) → number
Converts a Mercator angle, in the range -PI to PI, to a geodetic latitude in the range -PI/2 to PI/2.
mercatorAngle number The angle to convert.
Converts geodetic ellipsoid coordinates, in radians, to the equivalent Web Mercator X, Y, Z coordinates expressed in meters and returned in a Cartesian3. The height is copied unmodified to the Z coordinate.
cartographic Cartographic The cartographic coordinates in radians.
result Cartesian3 optional The instance to which to copy the result, or undefined if a new instance should be created.
The equivalent web mercator X, Y, Z coordinates, in meters.
Converts Web Mercator X, Y coordinates, expressed in meters, to a Cartographic containing geodetic ellipsoid coordinates. The Z coordinate is copied unmodified to the height.
cartesian Cartesian3 The web mercator Cartesian position to unrproject with height (z) in meters.
result Cartographic optional The instance to which to copy the result, or undefined if a new instance should be created.
The equivalent cartographic coordinates.
