GeographicProjection
A simple map projection where longitude and latitude are linearly mapped to X and Y by multiplying them by the Ellipsoid#maximumRadius. This projection is commonly known as geographic, equirectangular, equidistant cylindrical, or plate carrée. When using the WGS84 ellipsoid, it is also known as EPSG:4326.
new Cesium.GeographicProjection(ellipsoid)
Name Type Default Description
ellipsoid Ellipsoid Ellipsoid.default optional The ellipsoid.
Gets the Ellipsoid.
Projects a set of Cartographic coordinates, in radians, to map coordinates, in meters. X and Y are the longitude and latitude, respectively, multiplied by the maximum radius of the ellipsoid. Z is the unmodified height.
cartographic Cartographic The coordinates to project.
result Cartesian3 optional An instance into which to copy the result. If this parameter is undefined, a new instance is created and returned.
The projected coordinates. If the result parameter is not undefined, the coordinates are copied there and that instance is returned. Otherwise, a new instance is created and returned.
Unprojects a set of projected Cartesian3 coordinates, in meters, to Cartographic coordinates, in radians. Longitude and Latitude are the X and Y coordinates, respectively, divided by the maximum radius of the ellipsoid. Height is the unmodified Z coordinate.
cartesian Cartesian3 The Cartesian position to unproject with height (z) in meters.
result Cartographic optional An instance into which to copy the result. If this parameter is undefined, a new instance is created and returned.
The unprojected coordinates. If the result parameter is not undefined, the coordinates are copied there and that instance is returned. Otherwise, a new instance is created and returned.
