CesiumTerrainProvider
new Cesium.CesiumTerrainProvider(options)
To construct a CesiumTerrainProvider, call CesiumTerrainProvider.fromIonAssetId or CesiumTerrainProvider.fromUrl. Do not call the constructor directly.
A TerrainProvider that accesses terrain data in a Cesium terrain format. Terrain formats can be one of the following:
options CesiumTerrainProvider.ConstructorOptions optional An object describing initialization options
// Create Arctic DEM terrain with normals.
try {
    terrainProvider: await Cesium.CesiumTerrainProvider.fromIonAssetId(3956, {
      requestVertexNormals: true
} catch (error) {
  console.log(error);
Gets an object that can be used to determine availability of terrain from this provider, such as at points and in rectangles. This property may be undefined if availability information is not available. Note that this reflects tiles that are known to be available currently. Additional tiles may be discovered to be available in the future, e.g. if availability information exists deeper in the tree rather than it all being discoverable at the root. However, a tile that is available now will not become unavailable in the future.
Gets the credit to display when this terrain provider is active. Typically this is used to credit the source of the terrain.
Gets an event that is raised when the terrain provider encounters an asynchronous error. By subscribing to the event, you will be notified of the error and can potentially recover from it. Event listeners are passed an instance of TileProviderError.
Gets a value indicating whether or not the requested tiles include metadata.
readonly hasVertexNormals : boolean
Gets a value indicating whether or not the requested tiles include vertex normals.
Gets a value indicating whether or not the provider includes a water mask. The water mask indicates which areas of the globe are water rather than land, so they can be rendered as a reflective surface with animated waves.
Boolean flag that indicates if the client should request metadata from the server. Metadata is appended to the standard tile mesh data only if the client requests the metadata and if the server provides a metadata.
readonly requestVertexNormals : boolean
Boolean flag that indicates if the client should request vertex normals from the server. Vertex normals data is appended to the standard tile mesh data only if the client requests the vertex normals and if the server provides vertex normals.
readonly requestWaterMask : boolean
Boolean flag that indicates if the client should request a watermask from the server. Watermask data is appended to the standard tile mesh data only if the client requests the watermask and if the server provides a watermask.
static Cesium.CesiumTerrainProvider.fromIonAssetId(assetId, options) → Promise.<CesiumTerrainProvider>
Creates a TerrainProvider from a Cesium ion asset ID that accesses terrain data in a Cesium terrain format Terrain formats can be one of the following:
assetId number The Cesium ion asset id.
options CesiumTerrainProvider.ConstructorOptions optional An object describing initialization options.
Throws:
  • RuntimeError : layer.json does not specify a format
  • RuntimeError : layer.json specifies an unknown format
  • RuntimeError : layer.json specifies an unsupported quantized-mesh version
  • RuntimeError : layer.json does not specify a tiles property, or specifies an empty array
  • RuntimeError : layer.json does not specify any tile URL templates
try {
} catch (error) {
  console.log(error);
static Cesium.CesiumTerrainProvider.fromUrl(url, options) → Promise.<CesiumTerrainProvider>
Creates a TerrainProvider that accesses terrain data in a Cesium terrain format. Terrain formats can be one of the following:
url Resource | string | Promise.<Resource> | Promise.<string> The URL of the Cesium terrain server.
Throws:
try {
    terrainProvider: await Cesium.CesiumTerrainProvider.fromUrl(
      Cesium.IonResource.fromAssetId(3956), {
} catch (error) {
  console.log(error);
getLevelMaximumGeometricError(level) → number
Gets the maximum geometric error allowed in a tile at a given level.
level number The tile level for which to get the maximum geometric error.
The maximum geometric error.
getTileDataAvailable(x, y, level) → boolean|undefined
Determines whether data for a tile is available to be loaded.
x number The X coordinate of the tile for which to request geometry.
y number The Y coordinate of the tile for which to request geometry.
level number The level of the tile for which to request geometry.
Undefined if not supported or availability is unknown, otherwise true or false.
loadTileDataAvailability(x, y, level) → undefined|Promise.<void>
Makes sure we load availability data for a tile
Undefined if nothing need to be loaded or a Promise that resolves when all required tiles are loaded
requestTileGeometry(x, y, level, request) → Promise.<TerrainData>|undefined
Requests the geometry for a given tile. The result must include terrain data and may optionally include a water mask and an indication of which child tiles are available.
A promise for the requested geometry. If this method returns undefined instead of a promise, it is an indication that too many requests are already pending and the request will be retried later.
Type Definitions
Cesium.CesiumTerrainProvider.ConstructorOptions
Initialization options for the CesiumTerrainProvider constructor
Properties:
requestVertexNormals boolean <optional>
false Flag that indicates if the client should request additional lighting information from the server, in the form of per vertex normals if available.
requestWaterMask boolean <optional>
false Flag that indicates if the client should request per tile water masks from the server, if available.
requestMetadata boolean <optional>
true Flag that indicates if the client should request per tile metadata from the server, if available.
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
