GoogleEarthEnterpriseMapsProvider
new Cesium.GoogleEarthEnterpriseMapsProvider(options)
To construct a GoogleEarthEnterpriseMapsProvider, call GoogleEarthEnterpriseImageryProvider.fromUrl. Do not call the constructor directly.
Provides tiled imagery using the Google Earth Imagery API. Notes: This imagery provider does not work with the public Google Earth servers. It works with the Google Earth Enterprise Server. By default the Google Earth Enterprise server does not set the Cross-Origin Resource Sharing headers. You can either use a proxy server which adds these headers, or in the /opt/google/gehttpd/conf/gehttpd.conf and add the 'Header set Access-Control-Allow-Origin "*"' option to the '<Directory />' and '<Directory "/opt/google/gehttpd/htdocs">' directives. This provider is for use with 2D Maps API as part of Google Earth Enterprise. For 3D Earth API uses, it is necessary to use GoogleEarthEnterpriseImageryProvider
options GoogleEarthEnterpriseMapsProvider.ConstructorOptions Object describing initialization options
Throws:
  • RuntimeError : Could not find layer with channel (id) of options.channel.
  • RuntimeError : Could not find a version in channel (id) options.channel.
  • RuntimeError : Unsupported projection data.projection.
const google = await Cesium.GoogleEarthEnterpriseMapsProvider.fromUrl("https://earth.localdomain", 1008);
static Cesium.GoogleEarthEnterpriseMapsProvider.logoUrl : string
Gets or sets the URL to the Google Earth logo for display in the credit.
Gets the imagery channel (id) currently being used.
Gets the url path of the data on the Google Earth server.
Gets the type of data that is being requested from the provider.
Gets the URL of the Google Earth MapServer.
Gets the version of the data used by this provider.
static Cesium.GoogleEarthEnterpriseMapsProvider.fromUrl(url, options) → Promise.<GoogleEarthEnterpriseMapsProvider>
Creates a tiled imagery provider using the Google Earth Imagery API.
url Resource | string The url of the Google Earth server hosting the imagery.
options GoogleEarthEnterpriseMapsProvider.ConstructorOptions optional Object describing initialization options
The created GoogleEarthEnterpriseMapsProvider.
Throws:
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
Type Definitions
Cesium.GoogleEarthEnterpriseMapsProvider.ConstructorOptions
Initialization options for the GoogleEarthEnterpriseMapsProvider constructor
Properties:
channel number The channel (id) to be used when requesting data from the server. The channel number can be found by looking at the json file located at: earth.localdomain/default_map/query?request=Json&vars=geeServerDefs The /default_map path may differ depending on your Google Earth Enterprise server configuration. Look for the "id" that is associated with a "ImageryMaps" requestType. There may be more than one id available. Example: { layers: [ { id: 1002, requestType: "ImageryMaps" }, { id: 1007, requestType: "VectorMapsRaster" } ] }
path string <optional>
"/default_map" The path of the Google Earth server hosting the imagery.
The maximum level-of-detail supported by the Google Earth Enterprise server, or undefined if there is no limit.
tileDiscardPolicy TileDiscardPolicy <optional>
The policy that determines if a tile is invalid and should be discarded. To ensure that no tiles are discarded, construct and pass a NeverTileDiscardPolicy for this parameter.
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
