ClassificationPrimitive
new Cesium.ClassificationPrimitive(options)
A classification primitive represents a volume enclosing geometry in the Scene to be highlighted.
A primitive combines geometry instances with an Appearance that describes the full shading, including Material and RenderState. Roughly, the geometry instance defines the structure and placement, and the appearance defines the visual characteristics. Decoupling geometry and appearance allows us to mix and match most of them and add a new geometry or appearance independently of each other. Only PerInstanceColorAppearance with the same color across all instances is supported at this time when using ClassificationPrimitive directly. For full Appearance support when classifying terrain or 3D Tiles use GroundPrimitive instead.
For correct rendering, this feature requires the EXT_frag_depth WebGL extension. For hardware that do not support this extension, there will be rendering artifacts for some viewing angles.
Valid geometries are BoxGeometry, CylinderGeometry, EllipsoidGeometry, PolylineVolumeGeometry, and SphereGeometry.
Geometries that follow the surface of the ellipsoid, such as CircleGeometry, CorridorGeometry, EllipseGeometry, PolygonGeometry, and RectangleGeometry, are also valid if they are extruded volumes; otherwise, they will not be rendered.
Name Type Default Description
geometryInstances Array | GeometryInstance optional The geometry instances to render. This can either be a single instance or an array of length one.
appearance Appearance optional The appearance used to render the primitive. Defaults to PerInstanceColorAppearance when GeometryInstances have a color attribute.
show boolean true optional Determines if this primitive will be shown.
vertexCacheOptimize boolean false optional When true, geometry vertices are optimized for the pre and post-vertex-shader caches.
interleave boolean false optional When true, geometry vertex attributes are interleaved, which can slightly improve rendering performance but increases load time.
compressVertices boolean true optional When true, the geometry vertices are compressed, which will save memory.
releaseGeometryInstances boolean true optional When true, the primitive does not keep a reference to the input geometryInstances to save memory.
allowPicking boolean true optional When true, each geometry instance will only be pickable with Scene#pick. When false, GPU memory is saved.
asynchronous boolean true optional Determines if the primitive will be created asynchronously or block until ready. If false initializeTerrainHeights() must be called first.
classificationType ClassificationType ClassificationType.BOTH optional Determines whether terrain, 3D Tiles or both will be classified.
debugShowBoundingVolume boolean false optional For debugging only. Determines if this primitive's commands' bounding spheres are shown.
debugShowShadowVolume boolean false optional For debugging only. Determines if the shadow volume for each geometry in the primitive is drawn. Must be true on creation for the volumes to be created before the geometry is released or options.releaseGeometryInstance must be false.
Default Value: true
Determines if the geometry instances will be created and batched on a web worker.
Default Value: true
Default Value: ClassificationType.BOTH
When true, geometry vertices are compressed, which will save memory.
Default Value: true
This property is for debugging only; it is not for production use nor is it optimized.
Draws the bounding sphere for each draw command in the primitive.
Default Value: false
Draws the shadow volume for each geometry in the primitive.
The geometry instance rendered with this primitive. This may be undefined if options.releaseGeometryInstances is true when the primitive is constructed.
Changing this property after the primitive is rendered has no effect.
Because of the rendering technique used, all geometry instances must be the same color. If there is an instance with a differing color, a DeveloperError will be thrown on the first attempt to render.
Default Value: undefined
Determines if geometry vertex attributes are interleaved, which can slightly improve rendering performance.
Determines if the primitive is complete and ready to render. If this property is true, the primitive will be rendered the next time that ClassificationPrimitive#update is called.
readonly releaseGeometryInstances : boolean
Default Value: true
Determines if the primitive will be shown. This affects all geometry instances in the primitive.
Default Value: true
readonly vertexCacheOptimize : boolean
Default Value: true
static Cesium.ClassificationPrimitive.isSupported(scene) → boolean
Determines if ClassificationPrimitive rendering is supported.
scene Scene The scene.
true if ClassificationPrimitives are supported; otherwise, returns false
Destroys the WebGL resources held by this object. Destroying an object allows for deterministic release of WebGL resources, instead of relying on the garbage collector to destroy this object.
Throws:
e = e && e.destroy();
getGeometryInstanceAttributes(id) → object
Returns the modifiable per-instance attributes for a GeometryInstance.
id * The id of the GeometryInstance.
The typed array in the attribute's format or undefined if the is no instance with id.
Throws:
  • DeveloperError : must call update before calling getGeometryInstanceAttributes.
const attributes = primitive.getGeometryInstanceAttributes('an id');
attributes.color = Cesium.ColorGeometryInstanceAttribute.toValue(Cesium.Color.AQUA);
attributes.show = Cesium.ShowGeometryInstanceAttribute.toValue(true);
Called when Viewer or CesiumWidget render the scene to get the draw commands needed to render this primitive.
Do not call this function directly. This is documented just to list the exceptions that may be propagated when the scene is rendered:
Throws:
  • DeveloperError : All instance geometries must have the same primitiveType.
  • DeveloperError : Appearance and material have a uniform with the same name.
  • DeveloperError : Not all of the geometry instances have the same color attribute.
