SampledPositionProperty
new Cesium.SampledPositionProperty(referenceFrame, numberOfDerivatives)
A SampledProperty which is also a PositionProperty.
Name Type Default Description
referenceFrame ReferenceFrame ReferenceFrame.FIXED optional The reference frame in which the position is defined.
numberOfDerivatives number 0 optional The number of derivatives that accompany each position; i.e. velocity, acceleration, etc...
Gets or sets the amount of time to extrapolate backward before the property becomes undefined. A value of 0 will extrapolate forever.
Default Value: 0
Gets or sets the type of extrapolation to perform when a value is requested at a time before any available samples.
Default Value: ExtrapolationType.NONE
Gets the event that is raised whenever the definition of this property changes. The definition is considered to have changed if a call to getValue would return a different result for the same time.
Gets or sets the amount of time to extrapolate forward before the property becomes undefined. A value of 0 will extrapolate forever.
Default Value: 0
Gets or sets the type of extrapolation to perform when a value is requested at a time after any available samples.
Gets the interpolation algorithm to use when retrieving a value. Call setInterpolationOptions to set this.
Default Value: LinearApproximation
Gets the degree of interpolation to perform when retrieving a value. Call setInterpolationOptions to set this.
Default Value: 1
Gets a value indicating if this property is constant. A property is considered constant if getValue always returns the same result for the current definition.
The number of derivatives contained by this property; i.e. 0 for just position, 1 for velocity, etc.
Default Value: 0
Gets the reference frame in which the position is defined.
Default Value: ReferenceFrame.FIXED;
Adds a new sample.
time JulianDate The sample time.
position Cartesian3 The position at the provided time.
derivatives Array.<Cartesian3> optional The array of derivative values at the provided time.
addSamples(times, positions, derivatives)
Adds multiple samples via parallel arrays.
times Array.<JulianDate> An array of JulianDate instances where each index is a sample time.
positions Array.<Cartesian3> An array of Cartesian3 position instances, where each value corresponds to the provided time index.
derivatives Array.<Array> optional An array where each value is another array containing derivatives for the corresponding time index.
Throws:
addSamplesPackedArray(packedSamples, epoch)
Adds samples as a single packed array where each new sample is represented as a date, followed by the packed representation of the corresponding value and derivatives.
packedSamples Array.<number> The array of packed samples.
epoch JulianDate optional If any of the dates in packedSamples are numbers, they are considered an offset from this epoch, in seconds.
Compares this property to the provided property and returns true if they are equal, false otherwise.
other Property optional The other property.
Gets the position at the provided time.
time JulianDate JulianDate.now() optional The time for which to retrieve the value. If omitted, the current system time is used.
result Cartesian3 optional The object to store the value into, if omitted, a new instance is created and returned.
getValueInReferenceFrame(time, referenceFrame, result) → Cartesian3|undefined
Gets the position at the provided time and in the provided reference frame.
time JulianDate The time for which to retrieve the value.
referenceFrame ReferenceFrame The desired referenceFrame of the result.
Removes a sample at the given time, if present.
true if a sample at time was removed, false otherwise.
Removes all samples for the given time interval.
time TimeInterval The time interval for which to remove all samples.
Sets the algorithm and degree to use when interpolating a position.
interpolationAlgorithm InterpolationAlgorithm optional The new interpolation algorithm. If undefined, the existing property will be unchanged.
interpolationDegree number optional The new interpolation degree. If undefined, the existing property will be unchanged.
