A description of the outline of a sphere.
| Name | Type | Description | ||||||||||||||||||||
| options | object | optional
Throws:
    DeveloperError : options.stackPartitions must be greater than or equal to one.
    DeveloperError : options.slicePartitions must be greater than or equal to zero.
    DeveloperError : options.subdivisions must be greater than or equal to zero.
const sphere = new Cesium.SphereOutlineGeometry({
  radius : 100.0,
  stackPartitions : 6,
  slicePartitions: 5
const geometry = Cesium.SphereOutlineGeometry.createGeometry(sphere);Members
static Cesium.SphereOutlineGeometry.createGeometry(sphereGeometry) → Geometry|undefined
    Computes the geometric representation of an outline of a sphere, including its vertices, indices, and a bounding sphere.
| sphereGeometry | SphereOutlineGeometry | A description of the sphere outline. |
    The computed vertices and indices.
| value | SphereOutlineGeometry | The value to pack. | |
| array | Array.<number> | The array to pack into. | |
| startingIndex | number | 0 | optional The index into the array at which to start packing the elements. |
static Cesium.SphereOutlineGeometry.unpack(array, startingIndex, result) → SphereOutlineGeometry
| array | Array.<number> | The packed array. | |
| startingIndex | number | 0 | optional The starting index of the element to be unpacked. |
| result | SphereOutlineGeometry | optional The object into which to store the result. |
    The modified result parameter or a new SphereOutlineGeometry instance if one was not provided.
