A
Property that produces TranslationRotationScale data.
| Name | Type | Description | ||||||||||||||||
options |
object |
optional
The definition is considered to have changed if a call to getValue would return
a different result for the same time.
rotation : Property|undefined
Gets or sets the
Quaternion Property specifying the (x, y, z, w) rotation to apply to the node.
Default Value:
Quaternion.IDENTITY
scale : Property|undefined
Gets or sets the
Cartesian3 Property specifying the (x, y, z) scaling to apply to the node.
Default Value:
new Cartesian3(1.0, 1.0, 1.0)
translation : Property|undefined
Gets or sets the
Cartesian3 Property specifying the (x, y, z) translation to apply to the node.
Default Value:
Cartesian3.ZERO
other |
getValue(time, result) → TranslationRotationScale
time |
JulianDate |
JulianDate.now()
result |
TranslationRotationScale | optional The object to store the value into, if omitted, a new instance is created and returned. |
