A
Property which is defined by a TimeIntervalCollection, where the
data property of each TimeInterval represents the value at time.
//Create a Cartesian2 interval property which contains data on August 1st, 2012
//and uses a different value every 6 hours.
const composite = new Cesium.TimeIntervalCollectionProperty();
composite.intervals.addInterval(Cesium.TimeInterval.fromIso8601({
iso8601 : '2012-08-01T00:00:00.00Z/2012-08-01T06:00:00.00Z',
isStartIncluded : true,
isStopIncluded : false,
data : new Cesium.Cartesian2(2.0, 3.4)
iso8601 : '2012-08-01T06:00:00.00Z/2012-08-01T12:00:00.00Z',
data : new Cesium.Cartesian2(12.0, 2.7)
iso8601 : '2012-08-01T12:00:00.00Z/2012-08-01T18:00:00.00Z',
data : new Cesium.Cartesian2(5.0, 12.4)
iso8601 : '2012-08-01T18:00:00.00Z/2012-08-02T00:00:00.00Z',
isStopIncluded : true,
data : new Cesium.Cartesian2(85.0, 4.1)
The definition is changed whenever setValue is called with data different
than the current value.
readonly intervals : TimeIntervalCollection
Gets the interval collection.
| Name | Type | Description |
other |
time |
JulianDate |
JulianDate.now()
result |
object | optional The object to store the value into, if omitted, a new instance is created and returned. |
