TransformEditorViewModel
new IonSdkMeasurements.TransformEditorViewModel(options)
Creates an interactive transform editor
options Object An object with the following properties
Name Type Default Description
scene Scene The scene
transform Matrix4 The transform of the primitive that needs positioning
boundingSphere BoundingSphere The bounding sphere of the primitive that needs positioning
originOffset Cartesian3 optional A offset vector (in local coordinates) from the origin as defined by the transform translation.
pixelSize Number 100 optional The desired size of the transformation widget in pixels. Set this to zero to disable screen space scaling.
maximumSizeInMeters Number Infinity optional The maximum size of the transformation widget in meters. Set this to Infinity for no limit.
static IonSdkMeasurements.TransformEditorViewModel.originOffset : Cartesian3
Gets and sets the offset of the transform editor UI components from the origin as defined by the transform
readonly active : Boolean
Gets whether the widget is active. Use the activate and deactivate functions to set this value.
editorMode : EditorMode
Gets and sets the selected interactive mode.
enableNonUniformScaling : Boolean
Gets and sets whether non-uniform scaling is enabled
headingPitchRoll : HeadingPitchRoll
Gets and sets the heading pitch roll
readonly left : String
Gets the x screen coordinate of the widget menu
Gets and sets whether the menu is expanded
position : Cartesian3
Gets and sets the position
scale : Cartesian3
Gets and sets the scale
readonly top : String
Gets the y screen coordinate of the widget menu
activate()
Activates the widget by showing the primitives and enabling mouse handlers
deactivate()
Deactivates the widget by disabling mouse handlers and hiding the primitives
destroy()
Destroys the view model.
expandMenu()
Expands the widget menu
isDestroyed() → Boolean
true if the object has been destroyed, false otherwise.
setModeRotation()
Activates the rotation interactive mode
setModeScale()
Activates the scale interactive mode
setModeTranslation()
Activates the translation interactive mode
setOriginPosition(position)
Sets the originOffset based on the Cartesian3 position in world coordinates
position Cartesian3
toggleNonUniformScaling()
Toggles whether non-uniform scaling is enabled
