WebMapServiceImageryProvider
new Cesium.WebMapServiceImageryProvider(options)
Provides tiled imagery hosted by a Web Map Service (WMS) server.
options WebMapServiceImageryProvider.ConstructorOptions Object describing initialization options
// WMS servers operated by the US government https://apps.nationalmap.gov/services/
const provider = new Cesium.WebMapServiceImageryProvider({
    url : 'https://basemap.nationalmap.gov:443/arcgis/services/USGSHydroCached/MapServer/WMSServer',
    layers : '0',
    proxy: new Cesium.DefaultProxy('/proxy/')
const imageryLayer = new Cesium.ImageryLayer(provider);
viewer.imageryLayers.add(imageryLayer);
static constant Cesium.WebMapServiceImageryProvider.DefaultParameters : object
The default parameters to include in the WMS URL to obtain images. The values are as follows: service=WMS version=1.1.1 request=GetMap styles= format=image/jpeg
static constant Cesium.WebMapServiceImageryProvider.GetFeatureInfoDefaultParameters : object
The default parameters to include in the WMS URL to get feature information. The values are as follows: service=WMS version=1.1.1 request=GetFeatureInfo
Gets or sets a clock that is used to get keep the time used for time dynamic parameters.
Gets or sets a value indicating whether feature picking is enabled. If true, WebMapServiceImageryProvider#pickFeatures will invoke the GetFeatureInfo service on the WMS server and attempt to interpret the features included in the response. If false, WebMapServiceImageryProvider#pickFeatures will immediately return undefined (indicating no pickable features) without communicating with the server. Set this property to false if you know your data source does not support picking features or if you don't want this provider's features to be pickable.
Default Value: true
Gets the getFeatureInfo URL of the WMS server.
Gets the names of the WMS layers, separated by commas.
Gets or sets a time interval collection that is used to get time dynamic parameters. The data of each TimeInterval is an object containing the keys and values of the properties that are used during tile requests.
Gets the URL of the WMS server.
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → Promise.<Array.<ImageryLayerFeatureInfo>>|undefined
Asynchronously determines what features, if any, are located at a given longitude and latitude within a tile.
level number The tile level.
A promise for the picked features that will resolve when the asynchronous picking completes. The resolved value is an array of ImageryLayerFeatureInfo instances. The array may be empty if no features are found at the given location.
Type Definitions
Cesium.WebMapServiceImageryProvider.ConstructorOptions
Initialization options for the WebMapServiceImageryProvider constructor
Properties:
url Resource | string The URL of the WMS service. The URL supports the same keywords as the UrlTemplateImageryProvider.
layers string The layers to include, separated by commas.
parameters object <optional>
WebMapServiceImageryProvider.DefaultParameters Additional parameters to pass to the WMS server in the GetMap URL.
enablePickFeatures boolean <optional>
true If true, WebMapServiceImageryProvider#pickFeatures will invoke the GetFeatureInfo operation on the WMS server and return the features included in the response. If false, WebMapServiceImageryProvider#pickFeatures will immediately return undefined (indicating no pickable features) without communicating with the server. Set this property to false if you know your WMS server does not support GetFeatureInfo or if you don't want this provider's features to be pickable. Note that this can be dynamically overridden by modifying the WebMapServiceImageryProvider#enablePickFeatures property.
getFeatureInfoParameters object <optional>
WebMapServiceImageryProvider.GetFeatureInfoDefaultParameters Additional parameters to pass to the WMS server in the GetFeatureInfo URL.
getFeatureInfoUrl Resource | string <optional>
The getFeatureInfo URL of the WMS service. If the property is not defined then we use the property value of url.
getFeatureInfoFormats Array.<GetFeatureInfoFormat> <optional>
WebMapServiceImageryProvider.DefaultGetFeatureInfoFormats The formats in which to try WMS GetFeatureInfo requests. Since feature info responses vary across WMS services, you may need to supply a custom format and parsing callback; see the Sandcastle example for a complete example of writing your own callback.
Rectangle.MAX_VALUE The rectangle of the layer.
tilingScheme TilingScheme <optional>
new GeographicTilingScheme() The tiling scheme to use to divide the world into tiles.
The ellipsoid. If the tilingScheme is specified, this parameter is ignored and the tiling scheme's ellipsoid is used instead. If neither parameter is specified, the WGS84 ellipsoid is used.
tileWidth number <optional>
256 The width of each tile in pixels.
tileHeight number <optional>
256 The height of each tile in pixels.
minimumLevel number <optional>
0 The minimum level-of-detail supported by the imagery provider. Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
The maximum level-of-detail supported by the imagery provider, or undefined if there is no limit. If not specified, there is no limit.
crs string <optional>
CRS specification, for use with WMS specification >= 1.3.0.
srs string <optional>
SRS specification, for use with WMS specification 1.1.0 or 1.1.1
subdomains string | Array.<string> <optional>
'abc' The subdomains to use for the {s} placeholder in the URL template. If this parameter is a single string, each character in the string is a subdomain. If it is an array, each element in the array is a subdomain.
clock Clock <optional>
A Clock instance that is used when determining the value for the time dimension. Required when `times` is specified.
times TimeIntervalCollection <optional>
TimeIntervalCollection with its data property being an object containing time dynamic dimension and their values.
