Terrain data for a single tile where the terrain data is represented as a quantized mesh. A quantized
mesh consists of three vertex attributes, longitude, latitude, and height. All attributes are expressed
as 16-bit values in the range 0 to 32767. Longitude and latitude are zero at the southwest corner
of the tile and 32767 at the northeast corner. Height is zero at the minimum height in the tile
and 32767 at the maximum height in the tile.
| Name | Type | Description | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
options |
object |
const data = new Cesium.QuantizedMeshTerrainData({
minimumHeight : -100,
maximumHeight : 2101,
quantizedVertices : new Uint16Array([// order is SW NW SE NE
// longitude
0, 0, 32767, 32767,
// latitude
0, 32767, 0, 32767,
// heights
16384, 0, 32767, 16384]),
indices : new Uint16Array([0, 3, 1,
0, 2, 3]),
boundingSphere : new Cesium.BoundingSphere(new Cesium.Cartesian3(1.0, 2.0, 3.0), 10000),
orientedBoundingBox : new Cesium.OrientedBoundingBox(new Cesium.Cartesian3(1.0, 2.0, 3.0), Cesium.Matrix3.fromRotationX(Cesium.Math.PI, new Cesium.Matrix3())),
horizonOcclusionPoint : new Cesium.Cartesian3(3.0, 2.0, 1.0),
westIndices : [0, 1],
southIndices : [0, 1],
eastIndices : [2, 3],
northIndices : [1, 3],
westSkirtHeight : 1.0,
southSkirtHeight : 1.0,
eastSkirtHeight : 1.0,
northSkirtHeight : 1.0
credits : Array.<Credit>
An array of credits for this tile.
The water mask included in this terrain data, if any. A water mask is a rectangular
Uint8Array or image where a value of 255 indicates water and a value of 0 indicates land.
Values in between 0 and 255 are allowed as well to smoothly blend between land and water.
Computes the terrain height at a specified longitude and latitude.
rectangle |
Rectangle | The rectangle covered by this terrain data. |
longitude |
number | The longitude in radians. |
latitude |
number | The latitude in radians. |
The terrain height at the specified position. The position is clamped to
the rectangle, so expect incorrect results for positions far outside the rectangle.
Determines if a given child tile is available, based on the
QuantizedMeshTerrainData.childTileMask. The given child tile coordinates are assumed
to be one of the four children of this tile. If non-child tile coordinates are
given, the availability of the southeast child tile is returned.
thisX |
number | The tile X coordinate of this (the parent) tile. |
thisY |
number | The tile Y coordinate of this (the parent) tile. |
childX |
number | The tile X coordinate of the child tile to check for availability. |
childY |
number | The tile Y coordinate of the child tile to check for availability. |
True if the child tile is available; otherwise, false.
upsample(tilingScheme, thisX, thisY, thisLevel, descendantX, descendantY, descendantLevel) → Promise.<QuantizedMeshTerrainData>|undefined
Upsamples this terrain data for use by a descendant tile. The resulting instance will contain a subset of the
vertices in this instance, interpolated if necessary.
tilingScheme |
TilingScheme | The tiling scheme of this terrain data. |
thisX |
number | The X coordinate of this tile in the tiling scheme. |
thisY |
number | The Y coordinate of this tile in the tiling scheme. |
thisLevel |
number | The level of this tile in the tiling scheme. |
descendantX |
number | The X coordinate within the tiling scheme of the descendant tile for which we are upsampling. |
descendantY |
number | The Y coordinate within the tiling scheme of the descendant tile for which we are upsampling. |
descendantLevel |
number | The level within the tiling scheme of the descendant tile for which we are upsampling. |
A promise for upsampled heightmap terrain data for the descendant tile,
or undefined if too many asynchronous upsample operations are in progress and the request has been
deferred.
Gets a value indicating whether or not this terrain data was created by upsampling lower resolution
terrain data. If this value is false, the data was obtained from some other source, such
as by downloading it from a remote server. This method should return true for instances
returned from a call to
HeightmapTerrainData#upsample.
True if this instance was created by upsampling; otherwise, false.
