A
MaterialProperty that maps to grid Material uniforms.
| Name | Type | Description | ||||||||||||||||||||||||
options |
object |
optional
cellAlpha : Property|undefined
Gets or sets the numeric Property specifying cell alpha values.
Default Value:
0.1
color : Property|undefined
Gets or sets the Property specifying the grid
Color.
Default Value:
Color.WHITE
The definition is considered to have changed if a call to getValue would return
a different result for the same time.
lineCount : Property|undefined
Gets or sets the
Cartesian2 Property specifying the number of grid lines along each axis.
Default Value:
new Cartesian2(8.0, 8.0)
lineOffset : Property|undefined
Gets or sets the
Cartesian2 Property specifying the starting offset of grid lines along each axis.
Default Value:
new Cartesian2(0.0, 0.0)
lineThickness : Property|undefined
Gets or sets the
Cartesian2 Property specifying the thickness of grid lines along each axis.
Default Value:
new Cartesian2(1.0, 1.0)
other |
Gets the
Material type at the provided time.
time |
JulianDate | The time for which to retrieve the type. |
The type of material.
time |
JulianDate |
JulianDate.now()
result |
object | optional The object to store the value into, if omitted, a new instance is created and returned. |
