ImageMaterialProperty
new Cesium.ImageMaterialProperty(options)
A MaterialProperty that maps to image Material uniforms.
Name Type Default Description
image Property | string | HTMLImageElement | HTMLCanvasElement | HTMLVideoElement optional A Property specifying the Image, URL, Canvas, or Video.
repeat Property | Cartesian2 new Cartesian2(1.0, 1.0) optional A Cartesian2 Property specifying the number of times the image repeats in each direction.
color Property | Color Color.WHITE optional The color applied to the image
transparent Property | boolean false optional Set to true when the image has transparency (for example, when a png has transparent sections)
Gets or sets the Color Property specifying the desired color applied to the image.
Default Value: 1.0
Gets the event that is raised whenever the definition of this property changes. The definition is considered to have changed if a call to getValue would return a different result for the same time.
Gets or sets the Property specifying Image, URL, Canvas, or Video to use.
Gets a value indicating if this property is constant. A property is considered constant if getValue always returns the same result for the current definition.
Gets or sets the Cartesian2 Property specifying the number of times the image repeats in each direction.
Default Value: new Cartesian2(1, 1)
Gets or sets the Boolean Property specifying whether the image has transparency
Default Value: 1.0
Compares this property to the provided property and returns true if they are equal, false otherwise.
other Property optional The other property.
Gets the Material type at the provided time.
time JulianDate The time for which to retrieve the type.
The type of material.
time JulianDate JulianDate.now() optional The time for which to retrieve the value. If omitted, the current system time is used.
result object optional The object to store the value into, if omitted, a new instance is created and returned.
