A
Property whose value is an array whose items are the computed value
of other PositionProperty instances.
value |
Array.<Property> | optional An array of Property instances. | |
referenceFrame |
ReferenceFrame |
ReferenceFrame.FIXED
optional The reference frame in which the position is defined. |
The definition is changed whenever setValue is called with data different
than the current value or one of the properties in the array also changes.
Gets a value indicating if this property is constant. This property
is considered constant if all property items in the array are constant.
Gets the reference frame in which the position is defined.
Default Value:
ReferenceFrame.FIXED;
| Name | Type | Description |
other |
getValue(time, result) → Array.<Cartesian3>
Gets the value of the property.
time |
JulianDate |
JulianDate.now()
result |
Array.<Cartesian3> | optional The object to store the value into, if omitted, a new instance is created and returned. |
getValueInReferenceFrame(time, referenceFrame, result) → Array.<Cartesian3>
Gets the value of the property at the provided time and in the provided reference frame.
time |
JulianDate | The time for which to retrieve the value. |
referenceFrame |
ReferenceFrame | The desired referenceFrame of the result. |
result |
Sets the value of the property.
value |
Array.<Property> | An array of Property instances. |
