CameraEventAggregator
new Cesium.CameraEventAggregator(canvas)
Aggregates input events. For example, suppose the following inputs are received between frames: left mouse button down, mouse move, mouse move, left mouse button up. These events will be aggregated into one event with a start and end position of the mouse.
Name Type Default Description
canvas HTMLCanvasElement document optional The element to handle events for.
Gets whether any mouse button is down, a touch has started, or the wheel has been moved.
Gets the current mouse position.
Removes mouse listeners held by this object.
Throws:
handler = handler && handler.destroy();
getButtonPressTime(type, modifier) → Date
Gets the time the button was pressed or the touch was started.
type CameraEventType The camera event type.
modifier KeyboardEventModifier optional The keyboard modifier.
The time the button was pressed or the touch was started.
getButtonReleaseTime(type, modifier) → Date
Gets the time the button was released or the touch was ended.
The time the button was released or the touch was ended.
getLastMovement(type, modifier) → object|undefined
Gets the start and end position of the last move event (not the aggregated event).
An object with two Cartesian2 properties: startPosition and endPosition or undefined.
getMovement(type, modifier) → object
Gets the aggregated start and end position of the current event.
An object with two Cartesian2 properties: startPosition and endPosition.
getStartMousePosition(type, modifier) → Cartesian2
Gets the mouse position that started the aggregation.
The mouse position.
isButtonDown(type, modifier) → boolean
Gets whether the mouse button is down or a touch has started.
Whether the mouse button is down or a touch has started.
isMoving(type, modifier) → boolean
Gets if a mouse button down or touch has started and has been moved.
Returns true if a mouse button down or touch has started and has been moved; otherwise, false
Signals that all of the events have been handled and the aggregator should be reset to handle new events.
