An optionally time-dynamic pyramid.
| Name | Type | Description |
options |
RectangularSensorGraphics.ConstructorOptions | optional Object describing initialization options |
classificationType : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 369
Gets or sets the
ClassificationType Property specifying whether this sensor will classify terrain, 3D Tiles, or both.
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 133
Gets the event that is raised whenever a new property is assigned.
domeSurfaceMaterial : MaterialProperty
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 192
Gets or sets the
MaterialProperty specifying the the surface appearance of the sensor's dome.
ellipsoidHorizonSurfaceMaterial : MaterialProperty
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 174
Gets or sets the
MaterialProperty specifying the the sensor's ellipsoid horizon surface appearance.
ellipsoidSurfaceMaterial : MaterialProperty
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 206
Gets or sets the
MaterialProperty specifying the the sensor's ellipsoid surface appearance.
environmentConstraint : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 288
Gets or sets the boolean
Property determining if a sensor will intersect the environment, e.g. terrain or models,
and discard the portion of the sensor that is occluded.
environmentIntersectionColor : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 323
environmentIntersectionWidth : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 332
Gets or sets the
Property that approximate width in meters of the line intersecting the environment.
environmentOcclusionMaterial : MaterialProperty
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 305
Gets or sets the
MaterialProperty specifying the surface appearance of the portion of the sensor occluded by the environment.
intersectionColor : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 229
Gets or sets the
Color Property specifying the color of the line formed by the intersection of the pyramid and other central bodies.
intersectionWidth : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 236
Gets or sets the numeric
Property specifying the width of the line formed by the intersection of the pyramid and other central bodies.
lateralSurfaceMaterial : MaterialProperty
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 158
Gets or sets the
MaterialProperty specifying the the pyramid's appearance.
maximumRadius : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 273
Property specifying the maximum radius of the pyramid's projection.
This is equivalent to RectangularSensorGraphics#radius and takes precedence over it when both are provided.
minimumRadius : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 265
Property specifying the minimum radius of the pyramid's projection.
portionToDisplay : SensorVolumePortionToDisplay
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 222
Gets or sets the
SensorVolumePortionToDisplay specifying the portion of the sensor to display.
radius : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 258
Property specifying the radius of the pyramid's projection.
This is equivalent to RectangularSensorGraphics#maximumRadius, which takes precedence over this property when both are provided.
show : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 280
Property specifying the visibility of the pyramid.
showDomeSurfaces : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 199
Property specifying the visibility of the dome surfaces defining the sensor volume.
showEllipsoidHorizonSurfaces : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 183
Property specifying the visibility of the ellipsoid horizon surfaces defining the sensor volume.
showEllipsoidSurfaces : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 215
Property specifying the visibility of the ellipsoid surfaces defining the sensor volume.
showEnvironmentIntersection : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 314
Property that determines if a line is shown where the sensor intersects the environment, e.g. terrain or models.
showEnvironmentOcclusion : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 296
Property determining if the portion of the sensor occluded by the environment will be
drawn with RectangularSensorGraphics#environmentOcclusionMaterial.
showIntersection : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 243
Property specifying the visibility of the line formed by the intersection of the pyramid and other central bodies.
showLateralSurfaces : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 167
Property specifying the visibility of the lateral surfaces defining the sensor volume.
showThroughEllipsoid : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 250
Property specifying whether a sensor intersecting the ellipsoid is drawn through the ellipsoid and potentially out to the other side.
showViewshed : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 341
Property specifying the visibility of the viewshed.
viewshedOccludedColor : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 355
viewshedResolution : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 362
Gets or sets the
Property that controls the resolution in pixels of the viewshed.
viewshedVisibleColor : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 348
xHalfAngle : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 144
yHalfAngle : Property|undefined
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 151
clone(result) → RectangularSensorGraphics
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 378
Duplicates a RectangularSensorGraphics instance.
result |
RectangularSensorGraphics | optional The object onto which to store the result. |
The modified result parameter or a new instance if one was not provided.
Assigns each unassigned property on this object to the value
of the same property on the provided source object.
source |
RectangularSensorGraphics | The object to be merged into this object. |
Type Definitions
IonSdkSensors.RectangularSensorGraphics.ConstructorOptions
packages/ion-sdk-sensors/Source/DataSources/RectangularSensorGraphics.js 7
Initialization options for the RectangularSensorGraphics constructor
Properties:
| Name | Type | Attributes | Default | Description |
show |
Property | Boolean |
<optional> |
true | Determines if the sensor will be shown. |
portionToDisplay |
Property | SensorVolumePortionToDisplay |
<optional> |
SensorVolumePortionToDisplay.COMPLETE | Indicates what portion of the sensor is shown. |
radius |
Property | Number |
<optional> |
Number.POSITIVE_INFINITY | The distance from the sensor origin to any point on the sensor dome. Equivalent to maximumRadius, which takes precedence over this property when both are provided. |
minimumRadius |
Property | Number |
<optional> |
0.0 | The distance from the sensor origin to any point on the inner sensor dome. |
maximumRadius |
Property | Number |
<optional> |
Number.POSITIVE_INFINITY | The distance from the sensor origin to any point on the outer sensor dome. Equivalent to radius and takes precedence over it when both are provided. |
xHalfAngle |
Property | Number |
<optional> |
CesiumMath.PI_OVER_TWO | The half-angle, in radians, of the sensor measured from the positive z-axis (principal direction) along the x-axis. |
yHalfAngle |
Property | Number |
<optional> |
CesiumMath.PI_OVER_TWO | The half-angle, in radians, of the sensor measured from the positive z-axis (principal direction) along the y-axis. |
lateralSurfaceMaterial |
MaterialProperty | Color |
<optional> |
Color.WHITE | The surface appearance of the sensor lateral surface, i.e., the outer sides of the sensor. |
showLateralSurfaces |
<optional> |
true | Determines if the lateral surfaces, i.e., the outer sides of the sensor, are shown. |
ellipsoidHorizonSurfaceMaterial |
<optional> |
Color.WHITE | The surface appearance of the ellipsoid horizon surfaces, i.e., the sides formed from occlusion due to the ellipsoid horizon. |
showEllipsoidHorizonSurfaces |
<optional> |
true | Determines if the ellipsoid horizon surfaces, i.e., the sides formed from occlusion due to the ellipsoid horizon, are shown. |
ellipsoidSurfaceMaterial |
<optional> |
Color.WHITE | The appearance of the ellipsoid surface where the sensor intersects. |
showEllipsoidSurfaces |
<optional> |
true | Determines if the ellipsoid/sensor intersection surfaces are shown. |
domeSurfaceMaterial |
<optional> |
Color.WHITE | The appearance of the sensor dome surfaces. |
showDomeSurfaces |
<optional> |
true | Determines if the sensor dome surfaces are shown. |
showIntersection |
<optional> |
true | Determines if a polyline is shown where the sensor intersections the ellipsoid. |
intersectionColor |
Property | Color |
<optional> |
Color.WHITE | The color of the polyline where the sensor intersects the ellipsoid. |
intersectionWidth |
Property | Number |
<optional> |
5.0 | The approximate pixel width of the polyline where the sensor intersects the ellipsoid. |
showThroughEllipsoid |
<optional> |
false | Determines if a sensor intersecting the ellipsoid is drawn through the ellipsoid and potentially out to the other side. |
environmentConstraint |
<optional> |
false | Determines if the sensor will be occluded by the environment, e.g. terrain or models. |
showEnvironmentOcclusion |
<optional> |
false | Determines if the portion of the sensor occluded by the environment is shown. |
environmentOcclusionMaterial |
<optional> |
Color.WHITE | The appearance of the surface that is occluded by the environment. |
showEnvironmentIntersection |
<optional> |
false | Determines if the line intersecting the sensor and the environment is shown. |
environmentIntersectionColor |
Property | Color |
<optional> |
Color.WHITE | The color of the line intersecting the sensor and the environment. |
environmentIntersectionWidth |
Property | Number |
<optional> |
5.0 | The width of the line intersecting the sensor and the environment in meters. |
showViewshed |
<optional> |
false | The visibility of the viewshed. |
viewshedVisibleColor |
Property | Color |
<optional> |
Color.LIME | The color of the scene geometry that is visible to the sensor. |
viewshedOccludedColor |
Property | Color |
<optional> |
Color.RED | The color of the scene geometry that is not visible to the sensor. |
viewshedResolution |
Property | Number |
<optional> |
2048 | The resolution in pixels of the viewshed. |
classificationType |
Property | ClassificationType |
<optional> |
ClassificationType.BOTH | Whether this sensor will classify terrain, 3D Tiles, or both. |
