CallbackPositionProperty
new Cesium.CallbackPositionProperty(callback, isConstant, referenceFrame)
A PositionProperty whose value is lazily evaluated by a callback function.
Name Type Default Description
callback CallbackPositionProperty.Callback The function to be called when the position property is evaluated.
isConstant boolean true when the callback function returns the same value every time, false if the value will change.
referenceFrame ReferenceFrame ReferenceFrame.FIXED optional The reference frame in which the position is defined.
Demo:
Gets the event that is raised whenever the definition of this property changes. The definition is considered to have changed if a call to getValue would return a different result for the same time.
Gets a value indicating if this property is constant.
Gets the reference frame in which the position is defined.
Default Value: ReferenceFrame.FIXED;
Compares this property to the provided property and returns true if they are equal, false otherwise.
other Property optional The other property.
Gets the value of the property at the provided time in the fixed frame.
time JulianDate JulianDate.now() optional The time for which to retrieve the value. If omitted, the current system time is used.
result Cartesian3 optional The object to store the value into, if omitted, a new instance is created and returned.
getValueInReferenceFrame(time, referenceFrame, result) → Cartesian3|undefined
Gets the value of the property at the provided time and in the provided reference frame.
time JulianDate The time for which to retrieve the value.
referenceFrame ReferenceFrame The desired referenceFrame of the result.
Sets the callback to be used.
callback CallbackPositionProperty.Callback The function to be called when the property is evaluated.
Type Definitions
Cesium.CallbackPositionProperty.Callback(time, result) → Cartesian3|undefined
A function that returns the value of the position property.
result Cartesian3 optional The object to store the value into. If omitted, the function must create and return a new instance.
The modified result parameter, or a new instance if the result parameter was not supplied or is unsupported.
