The definition is changed whenever setValue is called with data different
than the current value.
intervals : TimeIntervalCollection
Gets the interval collection.
| Name | Type | Description |
other |
Gets the
Material type at the provided time.
time |
JulianDate | The time for which to retrieve the type. |
The type of material.
time |
JulianDate |
JulianDate.now()
result |
object | optional The object to store the value into, if omitted, a new instance is created and returned. |
