ClippingPolygonCollection
new Cesium.ClippingPolygonCollection(options)
Specifies a set of clipping polygons. Clipping polygons selectively disable rendering in a region inside or outside the specified list of ClippingPolygon objects for a single glTF model, 3D Tileset, or the globe. Clipping Polygons are only supported in WebGL 2 contexts.
Name Type Default Description
polygons Array.<ClippingPolygon> [] optional An array of ClippingPolygon objects used to selectively disable rendering on the inside of each polygon.
enabled boolean true optional Determines whether the clipping polygons are active.
inverse boolean false optional If true, a region will be clipped if it is outside of every polygon in the collection. Otherwise, a region will only be clipped if it is on the inside of any polygon.
quality number 1.0 optional A scalar that controls the resolution of the signed distance texture used for clipping. Values greater than 1.0 increase quality, values less than 1.0 decrease it. Must be greater than 0.0.
Deprecated in CesiumJS 1.145 and will be removed in 1.147. Signed distance field clipping was replaced with vector clipping, so this option no longer has any effect.
ellipsoid Ellipsoid Ellipsoid.default optional The ellipsoid to use to project the clipping polygons onto the globe.
const positions = Cesium.Cartesian3.fromRadiansArray([
    -1.3194369277314022,
    0.6988062530900625,
    -1.31941,
    0.69879,
    -1.3193955980204217,
    0.6988091578771254,
    -1.3193931220959367,
    0.698743632490865,
    -1.3194358224045408,
    0.6987471965556998,
const polygon = new Cesium.ClippingPolygon({
    positions: positions
const polygons = new Cesium.ClippingPolygonCollection({
   polygons: [ polygon ]
deprecated debugShowDistanceTexture : boolean
If true, a debug texture visualizing the signed distance field is shown.
Deprecated: This property was deprecated in CesiumJS 1.145 and will be removed in 1.147. Signed distance field clipping was replaced with vector clipping, so this property no longer has any effect.
Default Value: false
Default Value: Ellipsoid.default
If true, clipping will be enabled.
Default Value: true
If true, a region will be clipped if it is outside of every polygon in the collection. Otherwise, a region will only be clipped if it is inside of any polygon.
Returns the number of polygons in this collection. This is commonly used with ClippingPolygonCollection#get to iterate over all the polygons in the collection.
An event triggered when a new clipping polygon is added to the collection. Event handlers are passed the new polygon and the index at which it was added.
Default Value: Event()
An event triggered when a new clipping polygon is removed from the collection. Event handlers are passed the new polygon and the index from which it was removed.
A scalar that controlled the resolution of the signed distance texture used for clipping.
Default Value: 1.0
static Cesium.ClippingPolygonCollection.isSupported(scene) → boolean
Function for checking if the context will allow clipping polygons, which require floating point textures.
scene Scene | object The scene that will contain clipped objects and clipping textures.
true if the context supports clipping polygons.
Adds the specified ClippingPolygon to the collection to be used to selectively disable rendering on the inside of each polygon. Use ClippingPolygonCollection#unionClippingRegions to modify how modify the clipping behavior of multiple polygons.
polygon ClippingPolygon The ClippingPolygon to add to the collection.
The added ClippingPolygon.
const polygons = new Cesium.ClippingPolygonCollection();
    0.6988062530900625,
    -1.31941,
    0.69879,
    0.6988091578771254,
    0.698743632490865,
    0.6987471965556998,
polygons.add(new Cesium.ClippingPolygon({
Checks whether this collection contains a ClippingPolygon equal to the given ClippingPolygon.
polygon ClippingPolygon The ClippingPolygon to check for.
true if this collection contains the ClippingPolygon, false otherwise.
Destroys the WebGL resources held by this object. Destroying an object allows for deterministic release of WebGL resources, instead of relying on the garbage collector to destroy this object.
Throws:
Deprecated: This function was deprecated in CesiumJS 1.145 and will be removed in 1.147. The collection no longer holds any GPU resources of its own, so it does not need to be destroyed.
clippingPolygons = clippingPolygons && clippingPolygons.destroy();
Returns the clipping polygon in the collection at the specified index. Indices are zero-based and increase as polygons are added. Removing a polygon polygon all polygons after it to the left, changing their indices. This function is commonly used with ClippingPolygonCollection#length to iterate over all the polygons in the collection.
index number The zero-based index of the polygon.
The ClippingPolygon at the specified index.
Removes the first occurrence of the given ClippingPolygon from the collection.
true if the polygon was removed; false if the polygon was not found in the collection.
Removes all polygons from the collection.
