A
PositionProperty whose value does not change in respect to the
ReferenceFrame in which is it defined.
value |
Cartesian3 | optional The property value. | |
referenceFrame |
ReferenceFrame |
ReferenceFrame.FIXED
optional The reference frame in which the position is defined. |
The definition is considered to have changed if a call to getValue would return
a different result for the same time.
Gets the reference frame in which the position is defined.
Default Value:
ReferenceFrame.FIXED;
| Name | Type | Description |
other |
Gets the value of the property at the provided time in the fixed frame.
time |
JulianDate |
JulianDate.now()
result |
object | optional The object to store the value into, if omitted, a new instance is created and returned. |
getValueInReferenceFrame(time, referenceFrame, result) → Cartesian3
Gets the value of the property at the provided time and in the provided reference frame.
time |
JulianDate | The time for which to retrieve the value. |
referenceFrame |
ReferenceFrame | The desired referenceFrame of the result. |
result |
Cartesian3 | optional The object to store the value into, if omitted, a new instance is created and returned. |
Sets the value of the property.
value |
Cartesian3 | The property value. | |
referenceFrame |
ReferenceFrame |
this.referenceFrame
