CircleOutlineGeometry
new Cesium.CircleOutlineGeometry(options)
A description of the outline of a circle on the ellipsoid.
Name Type Default Description
center Cartesian3 The circle's center point in the fixed frame.
radius number The radius in meters.
ellipsoid Ellipsoid Ellipsoid.default optional The ellipsoid the circle will be on.
height number 0.0 optional The distance in meters between the circle and the ellipsoid surface.
granularity number 0.02 optional The angular distance between points on the circle in radians.
extrudedHeight number 0.0 optional The distance in meters between the circle's extruded face and the ellipsoid surface.
numberOfVerticalLines number 16 optional Number of lines to draw between the top and bottom of an extruded circle.
Throws:
// Create a circle.
const circle = new Cesium.CircleOutlineGeometry({
  center : Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883),
  radius : 100000.0
const geometry = Cesium.CircleOutlineGeometry.createGeometry(circle);
static Cesium.CircleOutlineGeometry.packedLength : number
static Cesium.CircleOutlineGeometry.createGeometry(circleGeometry) → Geometry|undefined
Computes the geometric representation of an outline of a circle on an ellipsoid, including its vertices, indices, and a bounding sphere.
circleGeometry CircleOutlineGeometry A description of the circle.
The computed vertices and indices.
static Cesium.CircleOutlineGeometry.pack(value, array, startingIndex) → Array.<number>
value CircleOutlineGeometry The value to pack.
array Array.<number> The array to pack into.
startingIndex number 0 optional The index into the array at which to start packing the elements.
static Cesium.CircleOutlineGeometry.unpack(array, startingIndex, result) → CircleOutlineGeometry
array Array.<number> The packed array.
startingIndex number 0 optional The starting index of the element to be unpacked.
result CircleOutlineGeometry optional The object into which to store the result.
The modified result parameter or a new CircleOutlineGeometry instance if one was not provided.
