minimum |
Cartesian3 |
Cartesian3.ZERO
optional The minimum point along the x, y, and z axes. |
maximum |
Cartesian3 |
Cartesian3.ZERO
optional The maximum point along the x, y, and z axes. |
center |
Cartesian3 | optional The center of the box; automatically computed if not supplied. |
The center point of the bounding box.
The maximum point defining the bounding box.
Default Value:
Cartesian3.ZERO
The minimum point defining the bounding box.
Default Value:
Cartesian3.ZERO
static Cesium.AxisAlignedBoundingBox.clone(box, result) → AxisAlignedBoundingBox
Duplicates a AxisAlignedBoundingBox instance.
| Name | Type | Description |
box |
AxisAlignedBoundingBox | The bounding box to duplicate. |
result |
AxisAlignedBoundingBox | optional The object onto which to store the result. |
The modified result parameter or a new AxisAlignedBoundingBox instance if none was provided. (Returns undefined if box is undefined)
Compares the provided AxisAlignedBoundingBox componentwise and returns
left |
AxisAlignedBoundingBox | optional The first AxisAlignedBoundingBox. |
right |
AxisAlignedBoundingBox | optional The second AxisAlignedBoundingBox. |
static Cesium.AxisAlignedBoundingBox.fromCorners(minimum, maximum, result) → AxisAlignedBoundingBox
Creates an instance of an AxisAlignedBoundingBox from its corners.
minimum |
Cartesian3 | The minimum point along the x, y, and z axes. |
maximum |
Cartesian3 | The maximum point along the x, y, and z axes. |
result |
The modified result parameter or a new AxisAlignedBoundingBox instance if one was not provided.
// Compute an axis aligned bounding box from the two corners.
const box = Cesium.AxisAlignedBoundingBox.fromCorners(new Cesium.Cartesian3(-1, -1, -1), new Cesium.Cartesian3(1, 1, 1));
static Cesium.AxisAlignedBoundingBox.fromPoints(positions, result) → AxisAlignedBoundingBox
Computes an instance of an AxisAlignedBoundingBox. The box is determined by
finding the points spaced the farthest apart on the x, y, and z axes.
positions |
Array.<Cartesian3> |
List of points that the bounding box will enclose. Each point must have a x, y, and z properties. |
result |
// Compute an axis aligned bounding box enclosing two points.
const box = Cesium.AxisAlignedBoundingBox.fromPoints([new Cesium.Cartesian3(2, 0, 0), new Cesium.Cartesian3(-2, 0, 0)]);
Determines whether two axis aligned bounding boxes intersect.
box |
AxisAlignedBoundingBox | first box |
other |
AxisAlignedBoundingBox | second box |
true if the boxes intersect; otherwise, false.
static Cesium.AxisAlignedBoundingBox.intersectPlane(box, plane) → Intersect
Determines which side of a plane a box is located.
box |
AxisAlignedBoundingBox | The bounding box to test. |
plane |
Plane | The plane to test against. |
Intersect.INSIDE if the entire box is on the side of the plane
the normal is pointing, Intersect.OUTSIDE if the entire box is
on the opposite side, and Intersect.INTERSECTING if the box
intersects the plane.
Duplicates this AxisAlignedBoundingBox instance.
result |
Compares this AxisAlignedBoundingBox against the provided AxisAlignedBoundingBox componentwise and returns
right |
AxisAlignedBoundingBox | optional The right hand side AxisAlignedBoundingBox. |
Determines whether some other axis aligned bounding box intersects this box.
other |
AxisAlignedBoundingBox | The other axis aligned bounding box. |
intersectPlane(plane) → Intersect
Determines which side of a plane this box is located.
plane |
