TileCoordinatesImageryProvider
new Cesium.TileCoordinatesImageryProvider(options)
An ImageryProvider that draws a box around every rendered tile in the tiling scheme, and draws a label inside it indicating the X, Y, Level coordinates of the tile. This is mostly useful for debugging terrain and imagery rendering problems.
options TileCoordinatesImageryProvider.ConstructorOptions optional Object describing initialization options
Gets a value indicating whether or not the images provided by this imagery provider include an alpha channel. If this property is false, an alpha channel, if present, will be ignored. If this property is true, any images without an alpha channel will be treated as if their alpha is 1.0 everywhere. Setting this property to false reduces memory usage and texture upload time.
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
requestImage(x, y, level, request) → Promise.<HTMLCanvasElement>
The resolved image as a Canvas DOM object.
Type Definitions
Cesium.TileCoordinatesImageryProvider.ConstructorOptions
Initialization options for the TileCoordinatesImageryProvider constructor
Properties:
tilingScheme TilingScheme <optional>
new GeographicTilingScheme() The tiling scheme for which to draw tiles.
The ellipsoid. If the tilingScheme is specified, this parameter is ignored and the tiling scheme's ellipsoid is used instead. If neither parameter is specified, the WGS84 ellipsoid is used.
color Color <optional>
Color.YELLOW The color to draw the tile box and label.
tileWidth number <optional>
256 The width of the tile for level-of-detail selection purposes.
tileHeight number <optional>
256 The height of the tile for level-of-detail selection purposes.
