A
MaterialProperty
that maps to PolylineArrow Material
uniforms.
Name | Type | Default | Description |
color |
Property | Color |
Color.WHITE
optional
The Color Property to be used. |
Default Value:
Color.WHITE
The definition is considered to have changed if a call to getValue would return
a different result for the same time.
true
if they are equal, false
otherwise.
Name | Type | Description |
other |
true
if left and right are equal, false
otherwise.
Gets the
Material
type at the provided time.
time |
JulianDate | The time for which to retrieve the type. |
The type of material.
time |
JulianDate | The time for which to retrieve the value. |
result |
object | optional The object to store the value into, if omitted, a new instance is created and returned. |
