Draws the outline of the camera's view frustum.
| Name | Type | Description | ||||||||||||||||||||||||||||
options |
object |
primitives.add(new Cesium.DebugCameraPrimitive({
camera : camera,
color : Cesium.Color.YELLOW
User-defined value returned when the primitive is picked.
Default Value:
undefined
Determines if this primitive will be shown.
Default Value:
true
Destroys the WebGL resources held by this object. Destroying an object allows for deterministic
release of WebGL resources, instead of relying on the garbage collector to destroy this object.
Once an object is destroyed, it should not be used; calling any function other than
isDestroyed will result in a DeveloperError exception. Therefore,
assign the return value (undefined) to the object as done in the example.
Throws:
p = p && p.destroy();
