ScreenSpaceEventHandler
new Cesium.ScreenSpaceEventHandler(element)
Handles user input events. Custom functions can be added to be executed on when the user enters input.
Name Type Default Description
element HTMLElement document optional The element to add events to.
static Cesium.ScreenSpaceEventHandler.mouseEmulationIgnoreMilliseconds : number
The amount of time, in milliseconds, that mouse events will be disabled after receiving any touch events, such that any emulated mouse events will be ignored.
Default Value: 800
static Cesium.ScreenSpaceEventHandler.touchHoldDelayMilliseconds : number
The amount of time, in milliseconds, before a touch on the screen becomes a touch and hold.
Default Value: 1500
Removes listeners held by this object.
Throws:
handler = handler && handler.destroy();
Returns the function to be executed on an input event.
type ScreenSpaceEventType The ScreenSpaceEventType of input event.
modifiers Array.<KeyboardEventModifier> | KeyboardEventModifier optional The KeyboardEventModifier keys that are held when a type event occurs.
The function to be executed on an input event.
Removes the function to be executed on an input event.
setInputAction(action, type, modifiers)
Set a function to be executed on an input event.
action ScreenSpaceEventHandler.PositionedEventCallback | ScreenSpaceEventHandler.MotionEventCallback | ScreenSpaceEventHandler.WheelEventCallback | ScreenSpaceEventHandler.TwoPointEventCallback | ScreenSpaceEventHandler.TwoPointMotionEventCallback Function to be executed when the input event occurs.
Type Definitions
Cesium.ScreenSpaceEventHandler.MotionEvent
An Event that starts at one position and ends at another.
Properties:
startPosition Cartesian2
endPosition Cartesian2
Cesium.ScreenSpaceEventHandler.MotionEventCallback(event)
event ScreenSpaceEventHandler.MotionEvent The event which triggered the listener
Cesium.ScreenSpaceEventHandler.PositionedEvent
An Event that occurs at a single position on screen.
Properties:
position Cartesian2
Cesium.ScreenSpaceEventHandler.PositionedEventCallback(event)
event ScreenSpaceEventHandler.PositionedEvent The event which triggered the listener
Cesium.ScreenSpaceEventHandler.TwoPointEvent
An Event that occurs at a two positions on screen.
Properties:
position1 Cartesian2
position2 Cartesian2
Cesium.ScreenSpaceEventHandler.TwoPointEventCallback(event)
event ScreenSpaceEventHandler.TwoPointEvent The event which triggered the listener
Cesium.ScreenSpaceEventHandler.TwoPointMotionEvent
An Event that starts at a two positions on screen and moves to two other positions.
Properties:
previousPosition1 Cartesian2
previousPosition2 Cartesian2
Cesium.ScreenSpaceEventHandler.TwoPointMotionEventCallback(event)
event ScreenSpaceEventHandler.TwoPointMotionEvent The event which triggered the listener
Cesium.ScreenSpaceEventHandler.WheelEventCallback(delta)
delta number The amount that the mouse wheel moved
