BingMapsImageryProvider
new Cesium.BingMapsImageryProvider(options)
To construct a BingMapsImageryProvider, call BingMapsImageryProvider.fromUrl. Do not call the constructor directly.
Provides tiled imagery using the Bing Maps Imagery REST API.
options BingMapsImageryProvider.ConstructorOptions Object describing initialization options
const bing = await Cesium.BingMapsImageryProvider.fromUrl(
  "https://dev.virtualearth.net", {
    key: "get-yours-at-https://www.bingmapsportal.com/",
    mapStyle: Cesium.BingMapsStyle.AERIAL
static Cesium.BingMapsImageryProvider.logoUrl : string
Gets or sets the URL to the Bing logo for display in the credit.
The culture to use when requesting Bing Maps imagery. Not all cultures are supported. See http://msdn.microsoft.com/en-us/library/hh441729.aspx for information on the supported cultures.
Gets a value indicating whether or not the images provided by this imagery provider include an alpha channel. If this property is false, an alpha channel, if present, will be ignored. If this property is true, any images without an alpha channel will be treated as if their alpha is 1.0 everywhere. Setting this property to false reduces memory usage and texture upload time.
Gets the Bing Maps key.
Gets the type of Bing Maps imagery to load.
Gets the name of the BingMaps server url hosting the imagery.
static Cesium.BingMapsImageryProvider.fromUrl(url, options) → Promise.<BingMapsImageryProvider>
Creates an ImageryProvider which provides tiled imagery using the Bing Maps Imagery REST API.
url Resource | string The url of the Bing Maps server hosting the imagery.
A promise that resolves to the created BingMapsImageryProvider
Throws:
  • RuntimeError : metadata does not specify one resource in resourceSets
static Cesium.BingMapsImageryProvider.quadKeyToTileXY(quadkey)
Converts a tile's quadkey used to request an image from a Bing Maps server into the (x, y, level) position.
quadkey string The tile's quad key
static Cesium.BingMapsImageryProvider.tileXYToQuadKey(x, y, level)
Converts a tiles (x, y, level) position into a quadkey used to request an image from a Bing Maps server.
x number The tile's x coordinate.
y number The tile's y coordinate.
level number The tile's zoom level.
getTileCredits(x, y, level) → Array.<Credit>
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
Type Definitions
Cesium.BingMapsImageryProvider.ConstructorOptions
Initialization options for the BingMapsImageryProvider constructor
Properties:
key string <optional>
The Bing Maps key for your application, which can be created at https://www.bingmapsportal.com/.
tileProtocol string <optional>
The protocol to use when loading tiles, e.g. 'http' or 'https'. By default, tiles are loaded using the same protocol as the page.
mapStyle BingMapsStyle <optional>
BingMapsStyle.AERIAL The type of Bing Maps imagery to load.
mapLayer string <optional>
Additional display layer options as defined on https://learn.microsoft.com/en-us/bingmaps/rest-services/imagery/get-imagery-metadata#template-parameters
culture string <optional>
'' The culture to use when requesting Bing Maps imagery. Not all cultures are supported. See http://msdn.microsoft.com/en-us/library/hh441729.aspx for information on the supported cultures.
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
tileDiscardPolicy TileDiscardPolicy <optional>
The policy that determines if a tile is invalid and should be discarded. By default, a DiscardEmptyTileImagePolicy will be used, with the expectation that the Bing Maps server will send a zero-length response for missing tiles. To ensure that no tiles are discarded, construct and pass a NeverTileDiscardPolicy for this parameter.
