ConditionsExpression
new Cesium.ConditionsExpression(conditionsExpression, defines)
An expression for a style applied to a Cesium3DTileset.
Evaluates a conditions expression defined using the 3D Tiles Styling language.
Implements the StyleExpression interface.
conditionsExpression object optional The conditions expression defined using the 3D Tiles Styling language.
defines object optional Defines in the style.
const expression = new Cesium.ConditionsExpression({
    conditions : [
        ['${Area} > 10, 'color("#FF0000")'],
        ['${id} !== "1"', 'color("#00FF00")'],
        ['true', 'color("#FFFFFF")']
expression.evaluateColor(feature, result); // returns a Cesium.Color object
readonly conditionsExpression : object
Gets the conditions expression defined in the 3D Tiles Styling language.
Default Value: undefined
evaluate(feature, result) → boolean|number|string|RegExp|Cartesian2|Cartesian3|Cartesian4|Color
Evaluates the result of an expression, optionally using the provided feature's properties. If the result of the expression in the 3D Tiles Styling language is of type Boolean, Number, or String, the corresponding JavaScript primitive type will be returned. If the result is a RegExp, a Javascript RegExp object will be returned. If the result is a Cartesian2, Cartesian3, or Cartesian4, a Cartesian2, Cartesian3, or Cartesian4 object will be returned. If the result argument is a Color, the Cartesian4 value is converted to a Color and then returned.
feature Cesium3DTileFeature The feature whose properties may be used as variables in the expression.
result object optional The object onto which to store the result.
The result of evaluating the expression.
Evaluates the result of a Color expression, using the values defined by a feature.
This is equivalent to ConditionsExpression#evaluate but always returns a Color object.
result Color optional The object in which to store the result
The modified result parameter or a new Color instance if one was not provided.
