Points are added and removed from the collection using
PointPrimitiveCollection#add
and PointPrimitiveCollection#remove.
Performance:
For best performance, prefer a few collections, each with many points, to many collections with only a few points each. Organize collections so that points with the same update frequency are in the same collection, i.e., points that do not change should be in one collection; points that change every frame should be in another collection; and so on.
| Name | Type | Description | ||||||||||||||||||||
options |
object |
optional
// Create a pointPrimitive collection with two points
const points = scene.primitives.add(new Cesium.PointPrimitiveCollection());
points.add({
position : new Cesium.Cartesian3(1.0, 2.0, 3.0),
color : Cesium.Color.YELLOW
points.add({
position : new Cesium.Cartesian3(4.0, 5.0, 6.0),
color : Cesium.Color.CYAN
Default Value:
BlendOption.OPAQUE_AND_TRANSLUCENT
Draws the bounding sphere for each draw command in the primitive.
Default Value:
false
PointPrimitiveCollection#get to iterate over all the points
in the collection.
Transforms.eastNorthUpToFixedFrame.
Default Value:
Matrix4.IDENTITY
const center = Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883);
pointPrimitives.modelMatrix = Cesium.Transforms.eastNorthUpToFixedFrame(center);
pointPrimitives.add({
color : Cesium.Color.ORANGE,
position : new Cesium.Cartesian3(0.0, 0.0, 0.0) // center
color : Cesium.Color.YELLOW,
position : new Cesium.Cartesian3(1000000.0, 0.0, 0.0) // east
color : Cesium.Color.GREEN,
position : new Cesium.Cartesian3(0.0, 1000000.0, 0.0) // north
color : Cesium.Color.CYAN,
position : new Cesium.Cartesian3(0.0, 0.0, 1000000.0) // up
Default Value:
true
Performance:
Calling add is expected constant time. However, the collection's vertex buffer
is rewritten - an O(n) operation that also incurs CPU to GPU overhead. For
best performance, add as many pointPrimitives as possible before calling update.
options |
object | optional A template describing the point's properties as shown in Example 1. |
Throws:
Examples:
// Example 1: Add a point, specifying all the default values.
const p = pointPrimitives.add({
show : true,
position : Cesium.Cartesian3.ZERO,
pixelSize : 10.0,
color : Cesium.Color.WHITE,
outlineColor : Cesium.Color.TRANSPARENT,
outlineWidth : 0.0,
// Example 2: Specify only the point's cartographic position.
position : Cesium.Cartesian3.fromDegrees(longitude, latitude, height)
pointPrimitive |
PointPrimitive | optional The point to check for. |
Once an object is destroyed, it should not be used; calling any function other than
isDestroyed will result in a DeveloperError exception. Therefore,
assign the return value (undefined) to the object as done in the example.
Throws:
pointPrimitives = pointPrimitives && pointPrimitives.destroy();
PointPrimitiveCollection#length to iterate over all the points
in the collection.
Performance:
Expected constant time. If points were removed from the collection and
PointPrimitiveCollection#update was not called, an implicit O(n)
operation is performed.
index |
number | The zero-based index of the point. |
Throws:
// Toggle the show property of every point in the collection
const len = pointPrimitives.length;
for (let i = 0; i < len; ++i) {
const p = pointPrimitives.get(i);
p.show = !p.show;
true if this object was destroyed; otherwise, false.
Performance:
Calling remove is expected constant time. However, the collection's vertex buffer
best performance, remove as many points as possible before calling update.
If you intend to temporarily hide a point, it is usually more efficient to call
PointPrimitive#show instead of removing and re-adding the point.
pointPrimitive |
PointPrimitive | The point to remove. |
true if the point was removed; false if the point was not found in the collection.
Throws:
const p = pointPrimitives.add(...);
pointPrimitives.remove(p); // Returns true
Performance:
O(n). It is more efficient to remove all the points
from a collection and then add new ones than to create a new collection entirely.
Throws:
pointPrimitives.removeAll();
