MapboxStyleImageryProvider
new Cesium.MapboxStyleImageryProvider(options)
Provides tiled imagery hosted by Mapbox.
options MapboxStyleImageryProvider.ConstructorOptions Object describing initialization options
// Mapbox style provider
const mapbox = new Cesium.MapboxStyleImageryProvider({
    styleId: 'streets-v11',
    accessToken: 'thisIsMyAccessToken'
Gets an event that is raised when the imagery provider encounters an asynchronous error.. By subscribing to the event, you will be notified of the error and can potentially recover from it. Event listeners are passed an instance of TileProviderError.
Gets the minimum level-of-detail that can be requested. Generally, a minimum level should only be used when the rectangle of the imagery is small enough that the number of tiles at the minimum level is small. An imagery provider with more than a few tiles at the minimum level will lead to rendering problems.
Gets the rectangle, in radians, of the imagery provided by the instance.
Gets the tiling scheme used by the provider.
Gets the URL of the Mapbox server.
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → Promise.<Array.<ImageryLayerFeatureInfo>>|undefined
Asynchronously determines what features, if any, are located at a given longitude and latitude within a tile. This function is optional, so it may not exist on all ImageryProviders.
level number The tile level.
A promise for the picked features that will resolve when the asynchronous picking completes. The resolved value is an array of ImageryLayerFeatureInfo instances. The array may be empty if no features are found at the given location. It may also be undefined if picking is not supported.
Type Definitions
Cesium.MapboxStyleImageryProvider.ConstructorOptions
Initialization options for the MapboxStyleImageryProvider constructor
Properties:
url Resource | string <optional>
'https://api.mapbox.com/styles/v1/' The Mapbox server url.
username string <optional>
'mapbox' The username of the map account.
styleId string The Mapbox Style ID.
accessToken string The public access token for the imagery.
tilesize number <optional>
512 The size of the image tiles.
scaleFactor boolean <optional>
Determines if tiles are rendered at a @2x scale factor.
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
minimumLevel number <optional>
0 The minimum level-of-detail supported by the imagery provider. Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
The maximum level-of-detail supported by the imagery provider, or undefined if there is no limit.
Rectangle.MAX_VALUE The rectangle, in radians, covered by the image.
