Cesium3DTilesVoxelProvider
new Cesium.Cesium3DTilesVoxelProvider(options)
A VoxelProvider that fetches voxel data from a 3D Tiles tileset.
Implements the VoxelProvider interface.
This object is normally not instantiated directly, use Cesium3DTilesVoxelProvider.fromUrl or Cesium3DTilesVoxelProvider.fromGltf.
options Cesium3DTilesVoxelProvider.ConstructorOptions An object describing initialization options
Experimental
Extends
readonly availableLevels : number|undefined
The number of levels of detail containing available tiles in the tileset.
The metadata class for this tileset.
Gets the metadata component types.
Gets the number of voxels per dimension of a tile. This is the same for all tiles in the dataset.
A transform from local space to global space.
Default Value: Matrix4.IDENTITY
Gets the maximum bounds. If undefined, the shape's default maximum bounds will be used instead.
readonly maximumTileCount : number|undefined
The maximum number of tiles that exist for this provider. This value is used as a hint to the voxel renderer to allocate an appropriate amount of GPU memory. If this value is not known it can be undefined.
readonly maximumValues : Array.<Array.<number>>|undefined
Gets the metadata maximum values.
Gets the minimum bounds. If undefined, the shape's default minimum bounds will be used instead.
readonly minimumValues : Array.<Array.<number>>|undefined
Gets the metadata minimum values.
Gets the metadata names.
Gets the number of padding voxels after the tile. This improves rendering quality when sampling the edge of a tile, but it increases memory usage.
Gets the number of padding voxels before the tile. This improves rendering quality when sampling the edge of a tile, but it increases memory usage.
Gets the VoxelShapeType
A transform from shape space to local space.
Gets the metadata types.
static Cesium.Cesium3DTilesVoxelProvider.fromGltf(url) → Promise.<Cesium3DTilesVoxelProvider>
Creates a Cesium3DTilesVoxelProvider that fetches voxel data from a 3D Tiles 2.0 tileset stored as glTF.
url Resource | string The URL to a glTF file with the 3DTILES_tileset and 3DTILES_tileset_voxels extensions
The created provider
Throws:
try {
  const voxelProvider = await Cesium3DTilesVoxelProvider.fromGltf(
    "http://localhost:8002/tilesets/voxel/voxels.tileset.gltf"
  const voxelPrimitive = new VoxelPrimitive({ provider: voxelProvider });
  scene.primitives.add(voxelPrimitive);
} catch (error) {
  console.error(`Error creating voxel primitive: ${error}`);
static Cesium.Cesium3DTilesVoxelProvider.fromUrl(url) → Promise.<Cesium3DTilesVoxelProvider>
Creates a Cesium3DTilesVoxelProvider that fetches voxel data from a 3D Tiles tileset.
url Resource | string The URL to a tileset JSON file
Throws:
  • RuntimeException : Root must have content
  • RuntimeException : Root tile content must have 3DTILES_content_voxels extension
  • RuntimeException : Root tile must have implicit tiling
  • RuntimeException : Tileset must have a metadata schema
  • RuntimeException : Only box, region and 3DTILES_bounding_volume_cylinder are supported in Cesium3DTilesVoxelProvider
try {
  const voxelProvider = await Cesium3DTilesVoxelProvider.fromUrl(
    "http://localhost:8002/tilesets/voxel/tileset.json"
    provider: voxelProvider,
    customShader: customShader,
} catch (error) {
Requests the data for a given tile.
Name Type Default Description
tileLevel number 0 optional The tile's level.
tileX number 0 optional The tile's X coordinate.
tileY number 0 optional The tile's Y coordinate.
tileZ number 0 optional The tile's Z coordinate.
A promise resolving to a VoxelContent containing the data for the tile, or undefined if the request could not be scheduled this frame.
Type Definitions
Cesium.Cesium3DTilesVoxelProvider.ConstructorOptions
Initialization options for the Cesium3DTilesVoxelProvider constructor
Properties:
className string The class in the tileset schema describing voxel metadata.
names Array.<string> The metadata names.
types Array.<MetadataType> The metadata types.
componentTypes Array.<MetadataComponentType> The metadata component types.
shape VoxelShapeType The VoxelShapeType.
dimensions Cartesian3 The number of voxels per dimension of a tile. This is the same for all tiles in the dataset.
paddingBefore Cartesian3 <optional>
Cartesian3.ZERO The number of padding voxels before the tile. This improves rendering quality when sampling the edge of a tile, but it increases memory usage.
paddingAfter Cartesian3 <optional>
Cartesian3.ZERO The number of padding voxels after the tile. This improves rendering quality when sampling the edge of a tile, but it increases memory usage.
globalTransform Matrix4 <optional>
Matrix4.IDENTITY A transform from local space to global space.
shapeTransform Matrix4 <optional>
Matrix4.IDENTITY A transform from shape space to local space.
minBounds Cartesian3 <optional>
The minimum bounds.
maxBounds Cartesian3 <optional>
The maximum bounds.
minimumValues Array.<Array.<number>> <optional>
The metadata minimum values.
maximumValues Array.<Array.<number>> <optional>
The metadata maximum values.
maximumTileCount number <optional>
