The view model for
ProjectionPicker
Name | Type | Description |
scene |
Scene | The Scene to switch projections. |
Gets or sets whether the button drop-down is currently visible. This property is observable.
Default Value:
false
isOrthographicProjection : Command
Gets whether the scene is currently using an orthographic projection.
Gets the scene
Gets or sets the current SceneMode. This property is observable.
Gets the currently active tooltip. This property is observable.
switchToOrthographic : Command
Gets the command to switch to orthographic projection.
switchToPerspective : Command
Gets the command to switch to a perspective projection.
Gets the command to toggle the drop down box.
Gets or sets the orthographic projection tooltip. This property is observable.
Default Value:
'Orthographic Projection'
Gets or sets the perspective projection tooltip. This property is observable.
Default Value:
'Perspective Projection'
Destroys the view model.
true if the object has been destroyed, false otherwise.
