A description of a polyline with a volume (a 2D shape extruded along a polyline).
| Name | Type | Description | ||||||||||||||||||||||||
options |
object |
- PolylineVolumeOutlineGeometry#createGeometry
function computeCircle(radius) {
const positions = [];
for (let i = 0; i < 360; i++) {
const radians = Cesium.Math.toRadians(i);
positions.push(new Cesium.Cartesian2(radius * Math.cos(radians), radius * Math.sin(radians)));
return positions;
const volumeOutline = new Cesium.PolylineVolumeOutlineGeometry({
polylinePositions : Cesium.Cartesian3.fromDegreesArray([
-72.0, 40.0,
-70.0, 35.0
shapePositions : computeCircle(100000.0)
static Cesium.PolylineVolumeOutlineGeometry.createGeometry(polylineVolumeOutlineGeometry) → Geometry|undefined
Computes the geometric representation of the outline of a polyline with a volume, including its vertices, indices, and a bounding sphere.
polylineVolumeOutlineGeometry |
PolylineVolumeOutlineGeometry | A description of the polyline volume outline. |
The computed vertices and indices.
value |
PolylineVolumeOutlineGeometry | The value to pack. | |
array |
Array.<number> | The array to pack into. | |
startingIndex |
number |
0
optional The index into the array at which to start packing the elements. |
static Cesium.PolylineVolumeOutlineGeometry.unpack(array, startingIndex, result) → PolylineVolumeOutlineGeometry
array |
Array.<number> | The packed array. | |
startingIndex |
number |
0
optional The starting index of the element to be unpacked. |
result |
PolylineVolumeOutlineGeometry | optional The object into which to store the result. |
The modified result parameter or a new PolylineVolumeOutlineGeometry instance if one was not provided.
