DistanceDisplayConditionGeometryInstanceAttribute
new Cesium.DistanceDisplayConditionGeometryInstanceAttribute(near, far)
Value and type information for per-instance geometry attribute that determines if the geometry instance has a distance display condition.
Name Type Default Description
near number 0.0 optional The near distance.
far number Number.MAX_VALUE optional The far distance.
Throws:
const instance = new Cesium.GeometryInstance({
  geometry : new Cesium.BoxGeometry({
    vertexFormat : Cesium.VertexFormat.POSITION_AND_NORMAL,
    minimum : new Cesium.Cartesian3(-250000.0, -250000.0, -250000.0),
    maximum : new Cesium.Cartesian3(250000.0, 250000.0, 250000.0)
  modelMatrix : Cesium.Matrix4.multiplyByTranslation(Cesium.Transforms.eastNorthUpToFixedFrame(
    Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883)), new Cesium.Cartesian3(0.0, 0.0, 1000000.0), new Cesium.Matrix4()),
  attributes : {
    distanceDisplayCondition : new Cesium.DistanceDisplayConditionGeometryInstanceAttribute(100.0, 10000.0)
The datatype of each component in the attribute, e.g., individual elements in DistanceDisplayConditionGeometryInstanceAttribute#value.
Default Value: ComponentDatatype.FLOAT
The number of components in the attributes, i.e., DistanceDisplayConditionGeometryInstanceAttribute#value.
Default Value: 3
When true and componentDatatype is an integer format, indicate that the components should be mapped to the range [0, 1] (unsigned) or [-1, 1] (signed) when they are accessed as floating-point for rendering.
Default Value: false
The values for the attributes stored in a typed array.
Default Value: [0.0, 0.0, Number.MAX_VALUE]
static Cesium.DistanceDisplayConditionGeometryInstanceAttribute.fromDistanceDisplayCondition(distanceDisplayCondition) → DistanceDisplayConditionGeometryInstanceAttribute
Creates a new DistanceDisplayConditionGeometryInstanceAttribute instance given the provided an enabled flag and DistanceDisplayCondition.
distanceDisplayCondition DistanceDisplayCondition The distance display condition.
Throws:
const distanceDisplayCondition = new Cesium.DistanceDisplayCondition(100.0, 10000.0);
  geometry : geometry,
  attributes : {
    distanceDisplayCondition : Cesium.DistanceDisplayConditionGeometryInstanceAttribute.fromDistanceDisplayCondition(distanceDisplayCondition)
static Cesium.DistanceDisplayConditionGeometryInstanceAttribute.toValue(distanceDisplayCondition, result) → Float32Array
Converts a distance display condition to a typed array that can be used to assign a distance display condition attribute.
distanceDisplayCondition DistanceDisplayCondition The distance display condition value.
result Float32Array optional The array to store the result in, if undefined a new instance will be created.
The modified result parameter or a new instance if result was undefined.
const attributes = primitive.getGeometryInstanceAttributes('an id');
attributes.distanceDisplayCondition = Cesium.DistanceDisplayConditionGeometryInstanceAttribute.toValue(distanceDisplayCondition, attributes.distanceDisplayCondition);
