A
CompositeProperty which is also a PositionProperty.
referenceFrame |
ReferenceFrame |
ReferenceFrame.FIXED
optional The reference frame in which the position is defined. |
The definition is changed whenever setValue is called with data different
than the current value.
intervals : TimeIntervalCollection
Gets the interval collection.
Gets or sets the reference frame which this position presents itself as.
Each PositionProperty making up this object has it's own reference frame,
so this property merely exposes a "preferred" reference frame for clients
to use.
| Name | Type | Description |
other |
getValue(time, result) → Cartesian3|undefined
Gets the value of the property at the provided time in the fixed frame.
time |
JulianDate |
JulianDate.now()
result |
Cartesian3 | optional The object to store the value into, if omitted, a new instance is created and returned. |
getValueInReferenceFrame(time, referenceFrame, result) → Cartesian3|undefined
Gets the value of the property at the provided time and in the provided reference frame.
time |
JulianDate | The time for which to retrieve the value. |
referenceFrame |
ReferenceFrame | The desired referenceFrame of the result. |
result |
