A
GeometryUpdater for polylines.
Clients do not normally create this class directly, but instead rely on DataSourceDisplay.
| Name | Type | Description |
entity |
Entity | The entity containing the geometry to be visualized. |
scene |
Scene | The scene where visualization is taking place. |
readonly arcType : ArcType
Gets a value indicating if the path of the line.
Gets a value indicating if the geometry is clamped to the ground.
Returns false if polylines on terrain is not supported.
readonly classificationTypeProperty : Property
Gets or sets the
ClassificationType Property specifying if this geometry will classify terrain, 3D Tiles, or both when on the ground.
readonly depthFailMaterialProperty : MaterialProperty
Gets the material property used to fill the geometry when it fails the depth test.
readonly distanceDisplayConditionProperty : Property
Gets or sets the
DistanceDisplayCondition Property specifying at what distance from the camera that this geometry will be displayed.
readonly entity : Entity
Gets the entity associated with this geometry.
Gets a value indicating if the geometry has a fill component.
readonly fillMaterialProperty : MaterialProperty
Gets the material property used to fill the geometry.
Gets an event that is raised whenever the public properties
of this updater change.
Gets a value indicating if fill visibility varies with simulation time.
Gets a value indicating if outline visibility varies with simulation time.
Gets the unique ID associated with this updater
Gets a value indicating if the geometry is closed.
This property is only valid for static geometry.
Gets a value indicating if the geometry is time-varying.
readonly outlineColorProperty : Property
Gets the
Color property for the geometry outline.
Gets a value indicating if the geometry has an outline component.
readonly shadowsProperty : Property
Gets the property specifying whether the geometry
casts or receives shadows from light sources.
Gets the zindex
createFillGeometryInstance(time) → GeometryInstance
Creates the geometry instance which represents the fill of the geometry.
time |
JulianDate | The time to use when retrieving initial attribute values. |
The geometry instance representing the filled portion of the geometry.
Throws:
DeveloperError : This instance does not represent a filled geometry.
createOutlineGeometryInstance(time) → GeometryInstance
Creates the geometry instance which represents the outline of the geometry.
time |
The geometry instance representing the outline portion of the geometry.
Throws:
DeveloperError : This instance does not represent an outlined geometry.
Destroys and resources used by the object. Once an object is destroyed, it should not be used.
Throws:
Checks if the geometry is filled at the provided time.
time |
JulianDate | The time for which to retrieve visibility. |
true if geometry is filled at the provided time, false otherwise.
Checks if the geometry is outlined at the provided time.
time |
true if geometry is outlined at the provided time, false otherwise.
