FrustumOutlineGeometry
new Cesium.FrustumOutlineGeometry(options)
A description of the outline of a frustum with the given the origin and orientation.
frustum PerspectiveFrustum | OrthographicFrustum The frustum.
origin Cartesian3 The origin of the frustum.
orientation Quaternion The orientation of the frustum.
static Cesium.FrustumOutlineGeometry.createGeometry(frustumGeometry) → Geometry|undefined
Computes the geometric representation of a frustum outline, including its vertices, indices, and a bounding sphere.
frustumGeometry FrustumOutlineGeometry A description of the frustum.
The computed vertices and indices.
static Cesium.FrustumOutlineGeometry.pack(value, array, startingIndex) → Array.<number>
Name Type Default Description
value FrustumOutlineGeometry The value to pack.
array Array.<number> The array to pack into.
startingIndex number 0 optional The index into the array at which to start packing the elements.
static Cesium.FrustumOutlineGeometry.unpack(array, startingIndex, result)
array Array.<number> The packed array.
startingIndex number 0 optional The starting index of the element to be unpacked.
result FrustumOutlineGeometry optional The object into which to store the result.
