A
Property
which evaluates to a Quaternion
rotation
based on the velocity of the provided PositionProperty
Name | Type | Default | Description |
position |
PositionProperty | optional The position property used to compute the orientation. | |
ellipsoid |
Ellipsoid |
Ellipsoid.default
optional The ellipsoid used to determine which way is up. |
//Create an entity with position and orientation.
const position = new Cesium.SampledProperty();
position.addSamples(...);
const entity = viewer.entities.add({
position : position,
orientation : new Cesium.VelocityOrientationProperty(position)
ellipsoid : Property|undefined
Gets or sets the ellipsoid used to determine which way is up.
Gets a value indicating if this property is constant.
position : Property|undefined
Gets or sets the position property used to compute orientation.
true
if they are equal, false
otherwise.
Name | Type | Description |
other |
true
if left and right are equal, false
otherwise.
getValue(time, result) → Quaternion
time |
JulianDate | optional The time for which to retrieve the value. |
result |
Quaternion | optional The object to store the value into, if omitted, a new instance is created and returned. |
