A
MaterialProperty that maps to checkerboard Material uniforms.
| Name | Type | Description | ||||||||||||||||
| options | object | optional
The definition is considered to have changed if a call to getValue would return
a different result for the same time.
evenColor : Property|undefined
    Gets or sets the Property specifying the first
Color.
    Default Value:
Color.WHITE
    Gets a value indicating if this property is constant.  A property is considered
oddColor : Property|undefined
    Gets or sets the Property specifying the second
Color.
    Default Value:
Color.BLACK
repeat : Property|undefined
    Gets or sets the
Cartesian2 Property specifying how many times the tiles repeat in each direction.
    Default Value:
new Cartesian2(2.0, 2.0)
| other | Property | optional The other property. |
    Gets the
Material type at the provided time.
| time | JulianDate | The time for which to retrieve the type. |
    The type of material.
| time | JulianDate | JulianDate.now() | optional The time for which to retrieve the value. If omitted, the current system time is used. |
| result | object | optional The object to store the value into, if omitted, a new instance is created and returned. |
