PostProcessStages and/or PostProcessStageComposites.
The input texture for each post-process stage is the texture rendered to by the scene or the texture rendered to by the previous stage in the collection.
If the ambient occlusion or bloom stages are enabled, they will execute before all other stages.
If the FXAA stage is enabled, it will execute after all other stages.
readonly ambientOcclusion : PostProcessStageComposite
Ambient occlusion simulates shadows from ambient light. These shadows would always be present when the surface receives light and regardless of the light's position.
The uniforms have the following properties:
intensityis a scalar value used to lighten or darken the shadows exponentially. Higher values make the shadows darker. The default value is3.0.biasis a scalar value representing an angle in radians. If the dot product between the normal of the sample and the vector to the camera is less than this value, sampling stops in the current direction. This is used to remove shadows from near planar edges. The default value is0.1.lengthCapis a scalar value representing a length in meters. If the distance from the current sample to first sample is greater than this value, sampling stops in the current direction. The default value is0.26.directionCountis the number of directions along which the ray marching will search for occluders. The default value is8.stepCountis the number of steps the ray marching will take along each direction. The default value is32.randomTextureis a texture where the red channel is a random value in [0.0, 1.0]. The default value isundefined. This texture needs to be set.ambientOcclusionOnlyis a boolean value. Whentrue, only the shadows generated are written to the output. Whenfalse, the input texture is modulated with the ambient occlusion. This is a useful debug option for seeing the effects of changing the uniform values. The default value isfalse.
When enabled, this stage will execute before all others.
readonly bloom : PostProcessStageComposite
A bloom effect adds glow effect, makes bright areas brighter, and dark areas darker.
This stage has the following uniforms: contrast, brightness, glowOnly,
delta, sigma, and stepSize.
contrastis a scalar value in the range [-255.0, 255.0] and affects the contract of the effect. The default value is128.0.brightnessis a scalar value. The input texture RGB value is converted to hue, saturation, and brightness (HSB) then this value is added to the brightness. The default value is-0.3.glowOnlyis a boolean value. Whentrue, only the glow effect will be shown. Whenfalse, the glow will be added to the input texture. The default value isfalse. This is a debug option for viewing the effects when changing the other uniform values.
delta, sigma, and stepSize are the same properties as PostProcessStageLibrary#createBlurStage.
The blur is applied to the shadows generated from the image to make them smoother.
Default Value:
1.0
viewer.scene.postProcessStages.exposure = 1.0;
When enabled, this stage will execute after all others.
Default Value:
Tonemapper.PBR_NEUTRAL
viewer.scene.postProcessStages.tonemapper = Cesium.Tonemapper.ACES;
add(stage) → PostProcessStage|PostProcessStageComposite
| Name | Type | Description |
stage |
PostProcessStage | PostProcessStageComposite | The post-process stage to add to the collection. |
Throws:
DeveloperError : The post-process stage has already been added to the collection or does not have a unique name.
stage |
PostProcessStage | PostProcessStageComposite | The post-process stage. |
Once an object is destroyed, it should not be used; calling any function other than
isDestroyed will result in a DeveloperError exception. Therefore,
assign the return value (undefined) to the object as done in the example.
Throws:
get(index) → PostProcessStage|PostProcessStageComposite
index.
index |
number | The index of the post-process stage. |
true if this object was destroyed; otherwise, false.
stage |
PostProcessStage | PostProcessStageComposite | The post-process stage to remove from the collection. |
