Azure2DImageryProvider
new Cesium.Azure2DImageryProvider(options)
Provides 2D image tiles from Azure.
options Azure2DImageryProvider.ConstructorOptions Object describing initialization options
// Azure 2D imagery provider
const azureImageryProvider = new Cesium.Azure2DImageryProvider({
    subscriptionKey: "subscription-key",
    tilesetId: "microsoft.base.road"
Gets an event that is raised when the imagery provider encounters an asynchronous error.. By subscribing to the event, you will be notified of the error and can potentially recover from it. Event listeners are passed an instance of TileProviderError.
Gets the minimum level-of-detail that can be requested. Generally, a minimum level should only be used when the rectangle of the imagery is small enough that the number of tiles at the minimum level is small. An imagery provider with more than a few tiles at the minimum level will lead to rendering problems.
Gets the rectangle, in radians, of the imagery provided by the instance.
Gets the tiling scheme used by the provider.
Gets the URL of the Azure 2D Imagery server.
getTileCredits(x, y, level) → Array.<Credit>|undefined
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
Type Definitions
Cesium.Azure2DImageryProvider.ConstructorOptions
Initialization options for the Azure2DImageryProvider constructor
Properties:
subscriptionKey string The public subscription key for the imagery.
url string <optional>
"https://atlas.microsoft.com/" The Azure server url.
tilesetId string <optional>
"microsoft.imagery" The Azure tileset ID. Valid options are microsoft.imagery, microsoft.base.road, and microsoft.base.labels.road
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
minimumLevel number <optional>
0 The minimum level-of-detail supported by the imagery provider. Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
22 The maximum level-of-detail supported by the imagery provider.
Rectangle.MAX_VALUE The rectangle, in radians, covered by the image.
