A 3D Tiles tileset represented by an
Entity.
The tileset modelMatrix is determined by the containing Entity position and orientation
or is left unset if position is undefined.
| Name | Type | Description |
options |
Cesium3DTilesetGraphics.ConstructorOptions | optional Object describing initialization options |
Gets the event that is raised whenever a property or sub-property is changed or modified.
maximumScreenSpaceError : Property|undefined
Gets or sets the maximum screen space error used to drive level of detail refinement.
show : Property|undefined
Gets or sets the boolean Property specifying the visibility of the model.
Default Value:
true
Gets or sets the string Property specifying the URI of the glTF asset.
clone(result) → Cesium3DTilesetGraphics
Duplicates this instance.
result |
Cesium3DTilesetGraphics | optional The object onto which to store the result. |
The modified result parameter or a new instance if one was not provided.
Assigns each unassigned property on this object to the value
of the same property on the provided source object.
source |
Cesium3DTilesetGraphics | The object to be merged into this object. |
Type Definitions
Initialization options for the Cesium3DTilesetGraphics constructor
Properties:
| Name | Type | Attributes | Default | Description |
show |
Property | boolean |
<optional> |
true | A boolean Property specifying the visibility of the tileset. |
uri |
Property | string | Resource |
<optional> |
A string or Resource Property specifying the URI of the tileset. | |
maximumScreenSpaceError |
Property | number |
<optional> |
A number or Property specifying the maximum screen space error used to drive level of detail refinement. |
