WebMapTileServiceImageryProvider
new Cesium.WebMapTileServiceImageryProvider(options)
Provides tiled imagery served by WMTS 1.0.0 compliant servers. This provider supports HTTP KVP-encoded and RESTful GetTile requests, but does not yet support the SOAP encoding.
options WebMapTileServiceImageryProvider.ConstructorOptions Object describing initialization options
Examples:
// Example 1. USGS shaded relief tiles (KVP)
const shadedRelief1 = new Cesium.WebMapTileServiceImageryProvider({
    url : 'https://basemap.nationalmap.gov/arcgis/rest/services/USGSShadedReliefOnly/MapServer/WMTS',
    layer : 'USGSShadedReliefOnly',
    style : 'default',
    format : 'image/jpeg',
    tileMatrixSetID : 'default028mm',
    // tileMatrixLabels : ['default028mm:0', 'default028mm:1', 'default028mm:2' ...],
    maximumLevel: 19,
    credit : new Cesium.Credit('U. S. Geological Survey')
viewer.imageryLayers.addImageryProvider(shadedRelief1);
// Example 2. USGS shaded relief tiles (RESTful)
const shadedRelief2 = new Cesium.WebMapTileServiceImageryProvider({
    url : 'https://basemap.nationalmap.gov/arcgis/rest/services/USGSShadedReliefOnly/MapServer/WMTS/tile/1.0.0/USGSShadedReliefOnly/{Style}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.jpg',
    style : 'default',
    maximumLevel: 19,
viewer.imageryLayers.addImageryProvider(shadedRelief2);
// Example 3: NASA time dynamic snowpack data (RESTful)
// Define time intervals for the layer based on the capabilities XML
const times = Cesium.TimeIntervalCollection.fromIso8601({
    iso8601: '2025-01-01/2025-09-01/P5D', // Use the valid interval(s) from the Dimension section
    dataCallback: function(interval, index) {
      // Return an object with the Time variable used in the URL template
      return {
          Time: Cesium.JulianDate.toIso8601(interval.start, 0)
// Get the internal clock,  set desired start, stop, and multiplier
const clock = viewer.clock;
clock.startTime = Cesium.JulianDate.fromIso8601('2025-01-01');
clock.currentTime = Cesium.JulianDate.fromIso8601('2025-01-01');
clock.stopTime = Cesium.JulianDate.fromIso8601('2025-09-01');
clock.clockRange = Cesium.ClockRange.LOOP_STOP;
clock.multiplier = 1; // 1 day per second
clock.clockStep = Cesium.ClockStep.SYSTEM_CLOCK_MULTIPLIER;
viewer.timeline.zoomTo(clock.startTime, clock.stopTime);
const weather = new Cesium.WebMapTileServiceImageryProvider({
    url: 'https://gibs.earthdata.nasa.gov/wmts/epsg3857/best/AMSRU2_Snow_Water_Equivalent_5Day/default/{Time}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.png',
    layer: 'AMSRU2_Snow_Water_Equivalent_5Day',
    style: 'default',
    tileMatrixSetID: 'GoogleMapsCompatible_Level6',
    format: 'image/png',
    clock: clock,
    times: times,
    credit: new Cesium.Credit('NASA Global Imagery Browse Services for EOSDIS')
viewer.imageryLayers.addImageryProvider(weather);
// Example 4. Digital Earth AfricA waterbodies with GetFeatureInfo support (RESTful)
const waterbodies = new Cesium.WebMapTileServiceImageryProvider({
   url: "https://geoserver.digitalearth.africa/geoserver/gwc/service/wmts/rest/{layer}/{style}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}?format={format}",
   layer: "waterbodies:DEAfrica_Waterbodies",
   style: "waterbodies:waterbodies_v0_0_4",
   tileMatrixSetID: "EPSG:3857",
   tileMatrixLabels: [
     "EPSG:3857:0",
     "EPSG:3857:1",
     "EPSG:3857:2",
     "EPSG:3857:3",
     "EPSG:3857:4",
     "EPSG:3857:5",
     "EPSG:3857:6",
     "EPSG:3857:7",
     "EPSG:3857:8",
     "EPSG:3857:9",
     "EPSG:3857:10",
     "EPSG:3857:11",
     "EPSG:3857:12",
     "EPSG:3857:13",
     "EPSG:3857:14",
     "EPSG:3857:15",
     "EPSG:3857:16",
     "EPSG:3857:17",
     "EPSG:3857:18",
     "EPSG:3857:19",
     "EPSG:3857:20",
     "EPSG:3857:21",
     "EPSG:3857:22",
     "EPSG:3857:23",
     "EPSG:3857:24",
     "EPSG:3857:25",
     "EPSG:3857:26",
     "EPSG:3857:27",
     "EPSG:3857:28",
     "EPSG:3857:29",
     "EPSG:3857:30",
   format: "image/png",
   enablePickFeatures: true,
   getFeatureInfoUrl: "https://geoserver.digitalearth.africa/geoserver/gwc/service/wmts/rest/{layer}/{style}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}/{j}/{i}?format={format}",
viewer.imageryLayers.addImageryProvider(waterbodies);
Demo:
static constant Cesium.WebMapTileServiceImageryProvider.DefaultParameters : object
The default parameters to include in the WMTS URL to obtain images. The values are as follows: service=WMTS version=1.0.0 request=GetTile
static constant Cesium.WebMapTileServiceImageryProvider.GetFeatureInfoDefaultParameters : object
The default parameters to include in the WMTS URL to get feature information. The values are as follows: service=WMTS version=1.0.0 request=GetFeatureInfo
Gets or sets a clock that is used to get keep the time used for time dynamic parameters.
Gets or sets an object that contains static dimensions and their values.
Gets or sets a value indicating whether feature picking is enabled. If true, WebMapTileServiceImageryProvider#pickFeatures will invoke the GetFeatureInfo service on the WMTS server and attempt to interpret the features included in the response. If false, WebMapTileServiceImageryProvider#pickFeatures will immediately return undefined (indicating no pickable features) without communicating with the server. Set this property to false if you know your data source does not support picking features or if you don't want this provider's features to be pickable. Defaults to true for KVP encoding. For RESTful encoding, defaults to true only when WebMapTileServiceImageryProvider.ConstructorOptions#getFeatureInfoUrl is specified, and false otherwise.
Gets the mime type of images returned by this imagery provider.
Gets the getFeatureInfo URL of the WMTS server.
Gets or sets a time interval collection that is used to get time dynamic parameters. The data of each TimeInterval is an object containing the keys and values of the properties that are used during tile requests.
Gets the URL of the service hosting the imagery.
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → Promise.<Array.<ImageryLayerFeatureInfo>>|undefined
Asynchronously determines what features, if any, are located at a given longitude and latitude within a tile.
level number The tile level.
A promise for the picked features that will resolve when the asynchronous picking completes. The resolved value is an array of ImageryLayerFeatureInfo instances. The array may be empty if no features are found at the given location.
Type Definitions
Cesium.WebMapTileServiceImageryProvider.ConstructorOptions
Initialization options for the WebMapTileServiceImageryProvider constructor
Properties:
url Resource | string The base URL for the WMTS GetTile operation (for KVP-encoded requests) or the tile-URL template (for RESTful requests). The tile-URL template should contain the following variables: {style}, {TileMatrixSet}, {TileMatrix}, {TileRow}, {TileCol}. The first two are optional if actual values are hardcoded or not required by the server. The {s} keyword may be used to specify subdomains.
format string <optional>
'image/jpeg' The MIME type for images to retrieve from the server.
layer string The layer name for WMTS requests.
style string The style name for WMTS requests.
tileMatrixSetID string The identifier of the TileMatrixSet to use for WMTS requests.
enablePickFeatures boolean <optional>
If true, WebMapTileServiceImageryProvider#pickFeatures will invoke the GetFeatureInfo operation on the WMTS server and return the features included in the response. If false, WebMapTileServiceImageryProvider#pickFeatures will immediately return undefined (indicating no pickable features) without communicating with the server. Set this property to false if you know your WMTS server does not support GetFeatureInfo or if you don't want this provider's features to be pickable. Defaults to true for KVP encoding. For RESTful encoding, defaults to true only when WebMapTileServiceImageryProvider.ConstructorOptions#getFeatureInfoUrl is specified, and false otherwise.
getFeatureInfoParameters object <optional>
Additional parameters to include in GetFeatureInfo requests. Keys are lowercased internally.
getFeatureInfoUrl Resource | string <optional>
The GetFeatureInfo URL of the WMTS service. If not specified, the value of url is used.
getFeatureInfoFormats Array.<GetFeatureInfoFormat> <optional>
WebMapTileServiceImageryProvider.DefaultGetFeatureInfoFormats The formats in which to try WMTS GetFeatureInfo requests. Since feature info responses vary across WMTS services, you may need to supply a custom format and parsing callback; see the Sandcastle example for a complete example of writing your own callback.
Rectangle.MAX_VALUE The rectangle covered by the layer.
tilingScheme TilingScheme <optional>
The tiling scheme corresponding to the organization of the tiles in the TileMatrixSet.
The ellipsoid. If not specified, the WGS84 ellipsoid is used.
tileWidth number <optional>
256 The tile width in pixels.
tileHeight number <optional>
256 The tile height in pixels.
minimumLevel number <optional>
0 The minimum level-of-detail supported by the imagery provider.
The maximum level-of-detail supported by the imagery provider, or undefined if there is no limit.
tileMatrixLabels Array <optional>
A list of identifiers in the TileMatrix to use for WMTS requests, one per TileMatrix level.
subdomains string | Array.<string> <optional>
'abc' The subdomains to use for the {s} placeholder in the URL template. If this parameter is a single string, each character in the string is a subdomain. If it is an array, each element in the array is a subdomain.
clock Clock <optional>
A Clock instance that is used when determining the value for the time dimension. Required when `times` is specified.
times TimeIntervalCollection <optional>
TimeIntervalCollection with its data property being an object containing time dynamic dimension and their values.
dimensions object <optional>
A object containing static dimensions and their values.
