Determines visibility based on the distance to the camera.
near |
number |
0.0
optional The smallest distance in the interval where the object is visible. |
far |
number |
Number.MAX_VALUE
optional The largest distance in the interval where the object is visible. |
// Make a billboard that is only visible when the distance to the camera is between 10 and 20 meters.
billboard.distanceDisplayCondition = new Cesium.DistanceDisplayCondition(10.0, 20.0);
Default Value:
Number.MAX_VALUE
Default Value:
0.0
static Cesium.DistanceDisplayCondition.clone(value, result) → DistanceDisplayCondition
Duplicates a distance display condition instance.
| Name | Type | Description |
value |
DistanceDisplayCondition | optional The distance display condition to duplicate. |
result |
DistanceDisplayCondition | optional The result onto which to store the result. |
The duplicated instance.
Determines if two distance display conditions are equal.
left |
DistanceDisplayCondition | optional A distance display condition. |
right |
DistanceDisplayCondition | optional Another distance display condition. |
Whether the two distance display conditions are equal.
value |
DistanceDisplayCondition | The value to pack. | |
array |
Array.<number> | The array to pack into. | |
startingIndex |
number |
0
optional The index into the array at which to start packing the elements. |
static Cesium.DistanceDisplayCondition.unpack(array, startingIndex, result) → DistanceDisplayCondition
array |
Array.<number> | The packed array. | |
startingIndex |
number |
0
optional The starting index of the element to be unpacked. |
result |
DistanceDisplayCondition | optional The object into which to store the result. |
The modified result parameter or a new DistanceDisplayCondition instance if one was not provided.
Duplicates this instance.
result |
Determines if this distance display condition is equal to another.
other |
Whether this distance display condition is equal to the other.
