ImageryLayerCollection
new Cesium.ImageryLayerCollection()
An ordered collection of imagery layers for rendering raster imagery on a Globe or Cesium3DTileset.
Demo:
An event that is raised when a layer is added to the collection. Event handlers are passed the layer that was added and the index at which it was added.
Default Value: Event()
An event that is raised when a layer changes position in the collection. Event handlers are passed the layer that was moved, its new index after the move, and its old index prior to the move.
An event that is raised when a layer is removed from the collection. Event handlers are passed the layer that was removed and the index from which it was removed.
An event that is raised when a layer is shown or hidden by setting the ImageryLayer#show property. Event handlers are passed a reference to this layer, the index of the layer in the collection, and a flag that is true if the layer is now shown or false if it is now hidden.
Gets the number of layers in this collection.
Adds a layer to the collection.
layer ImageryLayer the layer to add.
index number optional the index to add the layer at. If omitted, the layer will be added on top of all existing layers.
Throws:
  • DeveloperError : index, if supplied, must be greater than or equal to zero and less than or equal to the number of the layers.
Examples:
const imageryLayer = Cesium.ImageryLayer.fromWorldImagery();
scene.imageryLayers.add(imageryLayer);
const imageryLayer = Cesium.ImageryLayer.fromProviderAsync(Cesium.IonImageryProvider.fromAssetId(3812));
addImageryProvider(imageryProvider, index) → ImageryLayer
Creates a new layer using the given ImageryProvider and adds it to the collection.
imageryProvider ImageryProvider the imagery provider to create a new layer for.
index number optional the index to add the layer at. If omitted, the layer will added on top of all existing layers.
The newly created layer.
try {
   const provider = await Cesium.IonImageryProvider.fromAssetId(3812);
   scene.imageryLayers.addImageryProvider(provider);
} catch (error) {
  console.log(`There was an error creating the imagery layer. ${error}`)
Checks to see if the collection contains a given layer.
layer ImageryLayer the layer to check for.
true if the collection contains the layer, false otherwise.
Destroys the WebGL resources held by all layers in this collection. Explicitly destroying this object allows for deterministic release of WebGL resources, instead of relying on the garbage collector.
Once this object is destroyed, it should not be used; calling any function other than isDestroyed will result in a DeveloperError exception. Therefore, assign the return value (undefined) to the object as done in the example.
Throws:
layerCollection = layerCollection && layerCollection.destroy();
Gets a layer by index from the collection.
index number the index to retrieve.
The imagery layer at the given index.
Determines the index of a given layer in the collection.
layer ImageryLayer The layer to find the index of.
The index of the layer in the collection, or -1 if the layer does not exist in the collection.
Lowers a layer down one position in the collection.
layer ImageryLayer the layer to move.
Throws:
Lowers a layer to the bottom of the collection.
Throws:
pickImageryLayerFeatures(ray, scene) → Promise.<Array.<ImageryLayerFeatureInfo>>|undefined
Asynchronously determines the imagery layer features that are intersected by a pick ray. The intersected imagery layer features are found by invoking ImageryProvider#pickFeatures for each imagery layer tile intersected by the pick ray. To compute a pick ray from a location on the screen, use Camera.getPickRay.
ray Ray The ray to test for intersection.
scene Scene The scene.
A promise that resolves to an array of features intersected by the pick ray. If it can be quickly determined that no features are intersected (for example, because no active imagery providers support ImageryProvider#pickFeatures or because the pick ray does not intersect the surface), this function will return undefined.
const pickRay = viewer.camera.getPickRay(windowPosition);
const featuresPromise = viewer.imageryLayers.pickImageryLayerFeatures(pickRay, viewer.scene);
if (!Cesium.defined(featuresPromise)) {
    console.log('No features picked.');
} else {
    Promise.resolve(featuresPromise).then(function(features) {
        // This function is called asynchronously when the list if picked features is available.
        console.log(`Number of features: ${features.length}`);
        if (features.length > 0) {
            console.log(`First feature name: ${features[0].name}`);
pickImageryLayers(ray, scene) → Array.<ImageryLayer>|undefined
Determines the imagery layers that are intersected by a pick ray. To compute a pick ray from a location on the screen, use Camera.getPickRay.
An array that includes all of the layers that are intersected by a given pick ray. Undefined if no layers are selected.
Raises a layer up one position in the collection.
Throws:
Raises a layer to the top of the collection.
Throws:
Removes a layer from this collection, if present.
Name Type Default Description
layer ImageryLayer The layer to remove.
destroy boolean true optional whether to destroy the layers in addition to removing them.
true if the layer was in the collection and was removed, false if the layer was not in the collection.
Removes all layers from this collection.
