BufferPolygonCollection
Collection of polygons held in ArrayBuffer storage for performance and memory optimization.
Default buffer memory allocation is arbitrary, and collections cannot be resized, so specific per-buffer capacities should be provided in the collection constructor when available.
new Cesium.BufferPolygonCollection(options)
options BufferPolygonCollectionOptions optional
import earcut from "earcut";
const collection = new BufferPolygonCollection({
  primitiveCountMax: 1024,
  vertexCountMax: 4096,
  holeCountMax: 1024,
  triangleCountMax: 2048,
const polygon = new BufferPolygon();
const positions = [ ... ];
const holes = [ ... ];
const material = new BufferPolygonMaterial({color: Color.WHITE});
// Create a new polygon, temporarily bound to 'polygon' local variable.
collection.add({
  positions: new Float64Array(positions),
  holes: new Uint32Array(holes),
  triangles: new Uint32Array(earcut(positions, holes, 3)),
  material
}, polygon);
// Iterate over all polygons in collection, temporarily binding 'polygon'
// local variable to each, and updating polygon material.
for (let i = 0; i < collection.primitiveCount; i++) {
  collection.get(i, polygon);
  polygon.setMaterial(material);
Experimental
Extends
Total byte length of buffers owned by this collection. Includes any unused space allocated by primitiveCountMax, even if no polygons have yet been added in that space.
Number of holes in collection. Must be <= holeCountMax.
Maximum number of holes in collection. Must be >= holeCount.
Default Value: BufferPrimitiveCollection.DEFAULT_CAPACITY
Number of triangles in collection. Must be <= triangleCountMax.
Maximum number of triangles in collection. Must be >= triangleCount.
static Cesium.BufferPolygonCollection.clone(collection, result, predicate) → BufferPolygonCollection
Duplicates the contents of this collection into the result collection. Result collection is not resized, and must contain enough space for all primitives in the source collection. Existing polygons in the result collection will be overwritten.
Useful when allocating more space for a collection that has reached its capacity, and efficiently transferring polygons to the new collection.
collection BufferPolygonCollection
result BufferPolygonCollection
predicate function optional When provided, only polygons for which this returns true are copied. Surviving polygons are compacted into contiguous indices.
const result = new BufferPolygonCollection({ ... }); // allocate larger 'result' collection
BufferPolygonCollection.clone(collection, result);   // copy polygons from 'collection' into 'result'
static Cesium.BufferPolygonCollection.fromCollection(collection, options, predicate) → BufferPolygonCollection
Returns a copy of the given collection, overriding any constructor options provided. Omitted options are inherited from the source collection. Any resized buffers must be large enough to hold every polygon.
collection BufferPolygonCollection Source collection to copy.
options BufferPolygonCollectionOptions optional Constructor options to override. Omitted options are inherited from the source collection.
Adds a new polygon to the collection, with the specified options. A BufferPolygon instance is linked to the new polygon, using the 'result' argument if given, or a new instance if not. For repeated calls, prefer to reuse a single BufferPolygon instance rather than allocating a new instance on each call.
options BufferPolygonOptions
setPositions(positions, primitiveOffset, primitiveCount)
Updates vertex positions over the specified range of primitives. For position-only updates to many primitives, `setPositions()` is more efficient than updating each primitive individually. Argument `positions` must contain the same total number of vertices as the target primitive range; vertices cannot be added/removed by this method.
positions TypedArray
primitiveOffset number
primitiveCount number
