A description of a polyline on terrain or 3D Tiles. Only to be used with
GroundPolylinePrimitive.
| Name | Type | Description | ||||||||||||||||||||||||
| options | object | Options with the following properties:
Throws:
    DeveloperError : At least two positions are required.
const positions = Cesium.Cartesian3.fromDegreesArray([
  -112.1340164450331, 36.05494287836128,
  -112.08821010582645, 36.097804071380715,
  -112.13296079730024, 36.168769146801104
const geometry = new Cesium.GroundPolylineGeometry({
  positions : positions
});See:
    The type of path the polyline must follow. Valid options are
ArcType.GEODESIC and ArcType.RHUMB.
    Default Value:
ArcType.GEODESIC
    The distance interval used for interpolating options.points. Zero indicates no interpolation.
Default of 9999.0 allows centimeter accuracy with 32 bit floating point.
    Default Value:
9999.0
    Whether during geometry creation a line segment will be added between the last and first line positions to make this Polyline a loop.
If the geometry has two positions this parameter will be ignored.
    Default Value:
false
    The screen space width in pixels.
| value | PolygonGeometry | The value to pack. | |
| array | Array.<number> | The array to pack into. | |
| startingIndex | number | 0 | optional The index into the array at which to start packing the elements. |
| array | Array.<number> | The packed array. | |
| startingIndex | number | 0 | optional The starting index of the element to be unpacked. |
| result | PolygonGeometry | optional The object into which to store the result. |
