VRTheWorldTerrainProvider
new Cesium.VRTheWorldTerrainProvider(options)
To construct a VRTheWorldTerrainProvider, call VRTheWorldTerrainProvider.fromUrl. Do not call the constructor directly.
A TerrainProvider that produces terrain geometry by tessellating height maps retrieved from a VT MÄK VR-TheWorld server.
options VRTheWorldTerrainProvider.ConstructorOptions optional An object describing initialization options.
const terrainProvider = await Cesium.VRTheWorldTerrainProvider.fromUrl(
  "https://www.vr-theworld.com/vr-theworld/tiles1.0.0/73/"
viewer.terrainProvider = terrainProvider;
Gets an object that can be used to determine availability of terrain from this provider, such as at points and in rectangles. This property may be undefined if availability information is not available.
Gets the credit to display when this terrain provider is active. Typically this is used to credit the source of the terrain.
Gets an event that is raised when the terrain provider encounters an asynchronous error. By subscribing to the event, you will be notified of the error and can potentially recover from it. Event listeners are passed an instance of TileProviderError.
Gets a value indicating whether or not the requested tiles include vertex normals.
Gets a value indicating whether or not the provider includes a water mask. The water mask indicates which areas of the globe are water rather than land, so they can be rendered as a reflective surface with animated waves.
static Cesium.VRTheWorldTerrainProvider.fromUrl(url, options) → Promise.<VRTheWorldTerrainProvider>
Creates a TerrainProvider that produces terrain geometry by tessellating height maps retrieved from a VT MÄK VR-TheWorld server.
url Resource | string The URL of the VR-TheWorld TileMap.
Throws:
getLevelMaximumGeometricError(level) → number
Gets the maximum geometric error allowed in a tile at a given level.
level number The tile level for which to get the maximum geometric error.
The maximum geometric error.
getTileDataAvailable(x, y, level) → boolean|undefined
Determines whether data for a tile is available to be loaded.
x number The X coordinate of the tile for which to request geometry.
y number The Y coordinate of the tile for which to request geometry.
level number The level of the tile for which to request geometry.
Undefined if not supported, otherwise true or false.
loadTileDataAvailability(x, y, level) → undefined|Promise.<void>
Makes sure we load availability data for a tile
Undefined if nothing need to be loaded or a Promise that resolves when all required tiles are loaded
requestTileGeometry(x, y, level, request) → Promise.<TerrainData>|undefined
Requests the geometry for a given tile. The result includes terrain data and indicates that all child tiles are available.
A promise for the requested geometry. If this method returns undefined instead of a promise, it is an indication that too many requests are already pending and the request will be retried later.
Type Definitions
Cesium.VRTheWorldTerrainProvider.ConstructorOptions
Initialization options for the VRTheWorldTerrainProvider constructor
Properties:
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
