Google2DImageryProvider
new Cesium.Google2DImageryProvider(options)
This object is normally not instantiated directly, use Google2DImageryProvider.fromIonAssetId or Google2DImageryProvider.fromUrl.
Provides 2D image tiles from Google 2D Tiles. Google 2D Tiles can only be used with the Google geocoder.
options Google2DImageryProvider.ConstructorOptions Object describing initialization options
Examples:
// Google 2D imagery provider
const googleTilesProvider = Cesium.Google2DImageryProvider.fromIonAssetId({
    assetId: 3830184
// Use your own Google api key
Cesium.GoogleMaps.defaultApiKey = "your-api-key";
const googleTilesProvider = Cesium.Google2DImageryProvider.fromUrl({
    mapType: "SATELLITE"
Gets the minimum level-of-detail that can be requested. Generally, a minimum level should only be used when the rectangle of the imagery is small enough that the number of tiles at the minimum level is small. An imagery provider with more than a few tiles at the minimum level will lead to rendering problems.
Gets the rectangle, in radians, of the imagery provided by the instance.
Gets the tiling scheme used by the provider.
Gets the URL of the Google 2D Imagery server.
static Cesium.Google2DImageryProvider.fromIonAssetId(options) → Promise.<Google2DImageryProvider>
Creates an ImageryProvider which provides 2D global tiled imagery from Google 2D Tiles, streamed using the Cesium ion REST API.
Name Type Default Description
assetId string The Cesium ion asset id.
mapType "satellite" | "terrain" | "roadmap" "satellite" optional The map type of the Google map imagery. Valid options are satellite, terrain, and roadmap. If overlayLayerType is set, mapType is ignored and a transparent overlay is returned. If overlayMapType is undefined, then a basemap of mapType is returned. layerRoadmap overlayLayerType is included in terrain and roadmap mapTypes.
language string "en_US" optional an IETF language tag that specifies the language used to display information on the tiles
region string "US" optional A Common Locale Data Repository region identifier (two uppercase letters) that represents the physical location of the user.
overlayLayerType "layerRoadmap" | "layerStreetview" | "layerTraffic" optional Returns a transparent overlay map with the specified layerType. If no value is provided, a basemap of mapType is returned. Use multiple instances of Google2DImageryProvider to add multiple Google Maps overlays to a scene. layerRoadmap is included in terrain and roadmap mapTypes, so adding as overlay to terrain or roadmap has no effect.
styles object optional An array of JSON style objects that specify the appearance and detail level of map features such as roads, parks, and built-up areas. Styling is used to customize the standard Google base map. The styles parameter is valid only if the mapType is roadmap. For the complete style syntax, see the (Google Style Reference).
ellipsoid Ellipsoid Ellipsoid.default optional The ellipsoid. If not specified, the default ellipsoid is used.
minimumLevel number 0 optional The minimum level-of-detail supported by the imagery provider. Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
maximumLevel number 22 optional The maximum level-of-detail supported by the imagery provider.
rectangle Rectangle Rectangle.MAX_VALUE optional The rectangle, in radians, covered by the image.
credit Credit | string optional A credit for the data source, which is displayed on the canvas.
A promise that resolves to the created Google2DImageryProvider.
Examples:
    assetId: 3830184
// Google 2D roadmap overlay with custom styles
    assetId: 3830184,
    overlayLayerType: "layerRoadmap",
    styles: [
            stylers: [{ hue: "#00ffe6" }, { saturation: -20 }],
            featureType: "road",
            elementType: "geometry",
            stylers: [{ lightness: 100 }, { visibility: "simplified" }],
static Cesium.Google2DImageryProvider.fromUrl(options) → Promise.<Google2DImageryProvider>
Creates an ImageryProvider which provides 2D global tiled imagery from Google 2D Tiles.
key string GoogleMaps.defaultApiKey optional Your API key to access Google 2D Tiles. See https://developers.google.com/maps/documentation/javascript/get-api-key for instructions on how to create your own key.
Examples:
    mapType: "satellite"
    styles: [
getTileCredits(x, y, level) → Array.<Credit>|undefined
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
Type Definitions
Cesium.Google2DImageryProvider.ConstructorOptions
Initialization options for the Google2DImageryProvider constructor
Properties:
key string The Google api key to send with tile requests.
session string The Google session token that tracks the current state of your map and viewport.
url string | Resource | IonResource The Google 2D maps endpoint.
tileWidth string The width of each tile in pixels.
tileHeight string The height of each tile in pixels.
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
minimumLevel number <optional>
0 The minimum level-of-detail supported by the imagery provider. Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
22 The maximum level-of-detail supported by the imagery provider.
Rectangle.MAX_VALUE The rectangle, in radians, covered by the image.
